Calculate the potential (voltage) of a standard cell
To calculate the potential (voltage) of a standard cell using the given half-cell reactions, the standard reduction potentials (E°) for each half-reaction are necessary. The half-reaction for nickel has an E° of -0.25 V, while the half-reaction for chlorine has an E° of 1.360 V. The overall cell potential (E_cell) can be determined by subtracting the anode potential from the cathode potential. The calculated E_cell for the cell is approximately 1.110 V. This value indicates the voltage produced by the standard cell configuration.
Gab009
Calculate the potential (voltage) of a standard cell with these half-cell reactions:
Ni(s) -----> Ni2+ + 2 e-
2 e- + Cl2(g) -----> 2 Cl-
:cry:
What is your E_{cell} for each redox reaction?
Either they are in the problem, or there is a list that has all the E_{cell} for many reactions.
:cry:
Please read the posting guidelines - we can not do your homework for you.
https://www.physicsforums.com/showthread.php?t=93677
the first is -0.25; the second is 1.360
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
