Calculate the strength of several polycarbonate sheets laminated together
  • Thread starter Thread starter Plat
    Strength
Multiple thinner polycarbonate sheets bonded together exhibit greater strength than a single thicker sheet due to improved load distribution and reduced stress concentrations. The bonding process, using lacquer thinner, allows the sheets to fuse without introducing foreign materials, enhancing structural integrity. Calculating the strength of these laminations involves considering the combined Young's modulus and the adhesive's properties, though the adhesive's strength should ideally match or exceed that of the polycarbonate. Deflection testing indicates that adding layers significantly reduces deflection under load, with a notable exponential decrease observed. The tested configuration of four 2mm layers can support over 110kg without permanent deformation, demonstrating the effectiveness of this lamination technique.
Plat
Based on dimensions and the materials' Young's modulus, I know how to calculate the expected deflection of a rectangular sheet of material under a given distributed or point load and given various edge support conditions.
I have discovered however that multiple thinner sheets when bonded together are stronger than a single, thicker sheet of the same total thickness.
I am curious as to:
1. Why and how this is possible
2. How the strength of such multiple-sheet laminations may be calculated in terms of deflection under load assuming no bonding failure?
What kind of adhesive are you using, and how does its strength compare to that of the polycarbonate?
I have been using simple lacquer thinner to wet the surface of one sheet and then press another against it.
My understanding is that this solvent causes the polycarbonate from each piece to fuse together, leaving no foreign material or adhesive.
I have done deflection testing with a 20cm beam simply supported on each end, and applying three different masses to the center and measuring the downward deflection each produces with a micrometer. This deflection decreases exponentially (somewhere between power of 2.5 and 4.5) with each additional layer added.
With 4 layers of 2mm each, the 20cm inch beam can easily support at least 110kg in the center without permanent deformation.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
