What Bearings Suit a Shaft with Varying Loads and Diameters?
  • Thread starter Thread starter maths85
    Type
Selecting bearings for a shaft with varying loads and diameters requires careful consideration of calculated loads, which are 425 N and 375 N at points A and B, respectively. The shaft diameters are 15 mm at points A and B, and 20 mm at point C. Key factors in bearing selection include the shaft's rotational speed and the presence of axial forces, as some bearings can handle end thrust while others cannot. Standard deep groove ball bearings, particularly those with part numbers starting with 62xx, are recommended for their cost-effectiveness and availability. The NSK catalogue provides comprehensive technical selection data for various bearing types, aiding in the decision-making process.
maths85
I have to select bearings for the shaft using standard bearings catalogue depending on the calculated load.
In my shaft I calculate the loads and its 425 and 375 N in point A and B.
I should need to choose now what kind of bearings use and also using the diameter of the shaft that its dA=dB= 15 mm. and dC= 20 mm
All the large bearing manufacturers (eg NSK, SKF, NTN) have a huge amount of info on bearing selection. They are available online free, but you may need to make an account (also free).
For a more general introduction, I'd recommend Shigley's Mechanical Engineering Design.
Welcome to PF.
The type and size of bearing used is decided by several things. If the shaft rotates continuously then the RPM will be an important specification. Big bearings carry high loads, but only at slower speeds. If the shaft rotates slowly only part of a turn, a grease lubricated bronze or a Teflon bushing might solve the problem.
It is also necessary to identify the axial forces on the shaft. Some bearings can handle end thrust while others cannot. Start looking at low cost commodity bearings such as standard deep groove ball bearings. Usually standardised part numbers 62xx.
Download the Rolling Bearings section from here.
http://www.jp.nsk.com/app01/en/ctrg/index.cgi?gr=bearings
It starts with technical selection data, then goes on to list deep groove ball bearings and many others.
Thank you all of you. I found what I need it in the nsk catalogue.
Likes Baluncore
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
