Calculate Work Done by Force F on Mass 109g Object
  • Thread starter Thread starter strugglin-physics
    Work Work problem
To calculate the work done by a force on a mass, the dot product method is used, which involves the components of the force and displacement vectors. The formula W = F_x*d_x + F_y*d_y + F_z*d_z is applicable when the components are known, eliminating the need for the angle theta. The calculation revealed that the initial assumption of work being 101.4 was incorrect, as the correct approach requires proper unit consideration, given the force is in kN. To find the angle between the force and displacement, one can use the relationship W = Fd cos(theta) after determining the work done. Understanding these methods clarifies the process of calculating work in physics.
strugglin-physics
A force F = (11.5i + 9.62j + 13.2k)kN acts on a small object of mass 109g. If the displacement of the object is d = (5.63i + 3.81j) m, calculate the work done by the force.
I know W=F*d*cos theta so W=101.4 cos theta
How do I find theta? Do I use the inverse tangant of the F and the d?
The work done is defined by the dot product (or inner product) between the force vector and the displacement vector. In the cartesian coordinate system, we have
where F_x is the x-component of the force, d_x is the x-component of the displacement and similarly for others.
Kenneth
Right, got that part, I think.
W=11.5*5.63 + 9.62*3.81 + 13.2*0 = 101.4 cos theta
My question is how to find theta. would theta be the inverse tangant of 36.65/64.75?
W=11.5*5.63 + 9.62*3.81 + 13.2*0 = 101.4, not 101.4 cos (theta)!
There are (at least) two ways to calculate work, depending upon what you are given:
(1) W = F*d*cos(theta), is good if you are given the magnitude of the force and displacement and the angle between them.
(2) W = F_x*d_x + F_y*d_y + F_z*d_z, is good if you are given the components.
When you use method #2, theta is not needed.
It says that the answer is not 101.4
And the next questions says What is the angle between F and d?
Check the units. The force was given in kN.
If you know W, F, and d, then you can find theta using W = Fd cos(theta). F and d are the magnitudes of the vectors.
Ahh that makes sense. I was trying to figure it out without first finding the work. Thanks
