Calculating (125 2/3)^2: 3-Square-Root-of-5
  • Context: MHB
  • Thread starter Thread starter CSmith1
The discussion revolves around the calculation of \( (125^{2/3})^2 \) and the manipulation of square roots and cube roots in the context of mathematical expressions. Participants explore the steps involved in simplifying the expression and clarify the relationships between the operations of squaring and taking roots.
  • Homework-related
  • One participant presents the expression \( (125^{2/3})^2 \) and attempts to simplify it using square roots.
  • Another participant agrees with the initial steps taken and encourages the poster to solve more problems in a single post for efficiency.
  • Further simplification leads to the expression \( 3 \sqrt{5} \times 3 \sqrt{5} \), which is calculated to yield \( 9(5 \sqrt{5}) \) and \( 25 \sqrt{5} \).
  • A participant points out an error in the notation regarding the cube root and suggests that squaring and taking the cube root are opposite operations, emphasizing the importance of correct mathematical representation.
  • Another participant recommends learning LaTeX for better typesetting of mathematical expressions and provides examples of how to format the original question using LaTeX commands.
Participants generally agree on the initial steps of the calculation, but there are disagreements regarding the notation and the correctness of certain mathematical representations. The discussion remains unresolved on some points, particularly concerning the interpretation of cube roots and their notation.
There are limitations in the clarity of mathematical notation used by participants, which may lead to misunderstandings. The discussion also highlights the dependence on proper formatting for conveying mathematical ideas effectively.
CSmith1
1) 125 2/3(125 1/3)^2
=( 3 square root 125)^2
=(3 square root 5x5x5)^2
=(3 square root 5 )^2 right so far?
Mathematics news on Phys.org
Looks correct to me. Why don't you try solving a few problems fully and post them all at once to make this more efficient? :) It's better to type too much than not enough with online math help.
Good job by the way on learning this stuff!
OK.
CONTINUED
3 SQUARE ROOT 5 X 3 SQUARE ROOT 5
=9(5 SQUARE ROOT 5)
= 25 square root 5
CSmith said:
OK.
CONTINUED
=9(5 SQUARE ROOT 5)
= 25 square root 5
You got part of it right. The 3's will combine into 9 so now you must calculate the square root bits. After multiplying 3*3 you have [math]\sqrt{5} \cdot \sqrt{5}[/math] remaining, which is multiplied together. A common fact that is useful in these problems is that squaring and taking the square root are opposite operations, so when you do both to one number, nothing happens.
[math]\sqrt{5} \cdot \sqrt{5}=( \sqrt{5})^2=5[/math]
Now what do you get for your answer?
Hi CSmith, :)
Note that, \((\sqrt[3]{5\times 5\times 5})^2=5^2\). But you have written, \((\sqrt[3]{5\times 5\times 5})^2=(\sqrt[3]{5})^2\) which is incorrect.
Kind Regards,
Sudharaka.
Hi CSmith, :)
I went through most of your posts and it seems to me that you are making a lot of effort to typeset the mathematics in them. I suggest you to learn a bit of LaTeX commands. It's very easy. :) For starters, you can read the http://www.mathhelpboards.com/f26/ section.
As an example let me show you how to typeset your question in LaTeX.
Code:
\[125^{\frac{2}{3}}=(125^{\frac{1}{3}})^2\]
\[=(\sqrt[3]{125})^2\]
\[=(\sqrt[3]{5\times 5\times 5})^2\]
\[=(\sqrt[3]{5})^2\]
This will produce,
To make the equal signs align with each other you can use the "eqnarray" environment as follows,
Code:
\begin{eqnarray}
125^{\frac{2}{3}}&=&(125^{\frac{1}{3}})^2\\
&=&(\sqrt[3]{125})^2\\
&=&(\sqrt[3]{5\times 5\times 5})^2\\
&=&(\sqrt[3]{5})^2
\end{eqnarray}
will give you,
\begin{eqnarray}
&=&(\sqrt[3]{5})^2
\end{eqnarray}
Kind Regards,
Sudharaka.
  • · Replies 59 ·
230K
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 41 ·
