Calculating A in SHM from x, v & a
  • Thread starter Thread starter mudkip9001
    Shm
The discussion revolves around calculating the amplitude of an object in simple harmonic motion (SHM) using known values of displacement, velocity, and acceleration. Participants explore the relationships between these variables and the equations governing SHM, while expressing uncertainty about the necessary parameters for a complete solution.
  • Participants discuss the equations of motion in SHM and consider the implications of known values. Questions arise regarding the conditions at amplitude and the relationships between angular frequency, phase angle, and amplitude. Some participants express confusion about the solvability of the problem given the unknowns.
The discussion is active, with participants offering hints and guidance on using conservation of energy to relate the known quantities to the amplitude. There is acknowledgment of the complexity of the problem, and some participants are exploring different interpretations of the question, particularly regarding the final outcome and the nature of the calculations involved.
Participants note the absence of certain parameters, such as the spring constant and mass, which complicates the calculations. There is also mention of potential errors in the problem statement or textbook, leading to confusion about the expected results.
mudkip9001
how can you work out the amplitude knowing only displacement, velocity and acceleration?
I have been able to work out angular velocity, frequency and period, but I can't work out amplitude without knowing either the spring constant, the mass or the phase angle.
Welcome to PF,
Why don't you post what you have thus far?
HINT: What is the velocity of the particle when it is at it's amplitude?
Hootenanny said:
Welcome to PF,
Thank you, it seems like a nice place :)
I have these equations
x=Acos(\omegat+\phi)
v=-A\omegasin(\omegat + \phi)
a=-\omega^{2}cos(\omegat+\phi) =\omegax
I could work out \omega by re arranging the equation for a.
It's 0, but I'm still left with two unknown variables, \phi and A, am I not?
edit: why does omega keep showing up as superscript?
Have you any initial conditions, such as whether it starts from x=A or x=0?
Sorry, I should have typed up the question from the start:
You are watching an object in SHM. When the object is displaced 0.600m to the right of its equilibrium position, it has a velocity of 2.20 m/s to the right and an acceleration of 8.40 m/s^{2} to the left. How much farther from this point will the object move before it stops momentarily and then starts to move back to the left?
I struggled with this for hours and concluded that the question must be wrong, but I went to the homepage of the textbook and downloaded the errata and didn't find anything.
It seems to me that you have a system of simultaneous equations.
Which values of \left(\omega t + \phi\right) correspond to the particle being at x=A?
when x=A, \left(\omega t + \phi\right)=0
I still can't solve it though, I just end up with division of 0, can you confirm that it really is solvable?
Hi mudkip9001,
Try conservation of energy. Equate the energy at the given point to the energy at the amplitude. What do you get?
but I don't know neither k nor m
You'll be able to get rid of them by using what you know about the acceleration.
What I mean is that although you don't know either k or m, you can find the value of (k/m).
I just wrote all this, and then figured it out myself just as I finished. But I guess I might as well post t anyway. Thanks for all your help, I'm very relieved now (but I also feel a bit dumb, since I was so sure there was something wrong with the question).
Thanks, I never thought of that. However, I'm still not getting the same answer as the book:
\frac{1}{2}kx^{2} + \frac{1}{2}mv^{2} = \frac{1}{2}kA^{2}
solving for a gives me A=\sqrt{x^{2}+\frac{m}{k}v^{2}}
\frac{-x}{a}=\frac{m}{k}=0.0714
so
A=\sqrt{0.6^{2}+0.0714*2.2^{2}}=0.840m
but the book says 0.240m, where did I go wrong?
where I went wrong was that the question is how much further it would go, not the amplitude.
What you were missing is squaring the quantity m/k (i.e., A = \sqrt((x^2+v^2)/(x/a)^2)
(Sorry I couldn't write this in pretty-print. I'm new here.)
  • · Replies 27 ·
