Calculating calorie with the help of pedometer
  • Thread starter Thread starter anoop4real
To calculate calories burned using a pedometer, the user can determine the distance traveled by multiplying the number of steps by the predefined stride length. Several formulas are suggested, including calorie = weight (lbs) x distance (miles) and variations that include multipliers like 0.53 or 0.029. The discussion seeks clarity on which formula is the most accurate for calculating calories burned based on weight and distance. Users are encouraged to share their insights on the correct formula to use. Accurate calorie calculation can aid in fitness tracking and weight management.
anoop4real
Hi,
I feel I am posting in the right section, I was trying to calculate the calories burned with the help of number of steps walked, but not sure which formula I should use.
I have a predefined stride length
so distance traveled will be (no of steps x stride length) and I know my weight, with the help of these two whether I will be able to calculate calories burned??
I saw a different range of formulas
calorie=wt(lbs)xdistance(miles)
calorie=wt(lbs)xdistance(miles)x(.53)
calorie=wt(lbs)xdistance(miles)x(.029) etc
but which one is true, can anyone tell me the right formula to be used to calculate the calories burned.
thanks
bump!
any suggestions?
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
