Calculating Concentrations in a Saturated Solution of CaCl(2) and Ca(OH)2
  • Thread starter Thread starter sergey_le
    Ion
The discussion revolves around calculating the concentrations of calcium ions in a saturated solution of CaCl2 and Ca(OH)2, based on experimental data from a lab. Participants explore the implications of pH measurements and the solubility product constant (Ksp) of Ca(OH)2 in their calculations.
  • Technical explanation, Debate/contested, Experimental/applied
  • One participant describes their lab experiment, noting the preparation of a saturated solution and the measured pH, leading to a calculated OH- concentration of 0.027 M.
  • The participant references a previous lab report that calculated calcium concentration using a 1:2 ratio of OH- to Ca2+ ions and the concentration derived from CaCl2.
  • Another participant questions the validity of the previous lab report's approach, suggesting that the Ksp of Ca(OH)2 should be considered in the calculations.
  • There is a challenge regarding whether the initial participant's understanding or the previous report's method is correct, with a suggestion that the report's approach may be flawed.
  • A later reply indicates that the report's approach appears incorrect but does not provide an alternative calculation method.
Participants express disagreement regarding the method used in the previous lab report for calculating calcium concentration. There is no consensus on the correct approach to the calculations, and multiple viewpoints are presented.
Participants have not resolved the implications of the Ksp of Ca(OH)2 on the calculations, and there are uncertainties regarding the assumptions made in the previous lab report's methodology.
sergey_le
Summary:: finding concetrations
[Thread moved from the technical forums]
i did a lab experiment and I'm a little confused about what i should do.
i got a solution of CaCl(2) 1.5 gr and Ca(OH)2 5gr in 100ml that i prepared 2 weeks ahead
. after filttering the solution i got a saturated solution of CaCl(2) +Ca(OH)2.i tested the pH of it.(it is 12.43)
from the Ph value i got that OH concetration is 0.027M. the next quetion i need to answer is whet is the concentration of Ca. so i was seeing a lab report from a year ago, and to calculate the Ca consentration they first used the OH saturation (1:2) ratio. so 0.027/2=0.0135M. after that they calculated the amount of Ca from the CaCl(2) salt (1.5gr/110.98(gr/mol)=0.0137m/0.1l) which is 0.137M. they concluded that the ca consentration is 0.137+0.0135M.
i don't understand why. we calculate the consentration for a saturated solution, so there are no Ca ions from the CaCl(2) just floating and reacting...they already reacted and the axcess already sunk and turned to a solid, no?
Nope, doesn't look like a correct approach to me.
Hint: what is the Ksp of Ca(OH)2?
my approach is wrong or the one in the lasts year lab report?
Sorry, report approach looks wrong.
Technically you just expressed your concerns but never stated what would be your approach to calculations :smile:
10K
10K
