Engineering Calculating Current in Thevenin Equivalent Circuit?
To calculate the current in a Thevenin equivalent circuit, first determine the Thevenin resistance (Rth) by deactivating all sources and measuring the resistance between points A and B. Kirchhoff's Current Law (KCL) can be applied at the node with the -8.7V voltage to find the short-circuit current (Isc). The node voltages of -6.7V and -8.7V are relevant for calculating Isc, and the 1mA source should be considered in parallel with a short circuit. When applying KCL at node A, the correct equation is IR10 = Isource + I, ensuring the current directions are properly accounted for. Understanding these principles will facilitate accurate calculations in complex circuits.
john88
I trying to figure out a thevenin equivalent circuit
I want to calculate the current I so I can't get the resistance for the thevenin equivalent.
Im not 100% sure how to calculate I, can I use KCL on the node under the number -8.7V?
http://img98.imageshack.us/my.php?image=curfc7.jpg
That sure is a complex circuit. To find Rth, kill all the current and voltage sources and then measure the equivalent resistance between A&B.
KCL is valid everywhere. Is that -6.7 and -8.7 node voltages given by the question? If so, then you can easily find Isc. Also note that the 1mA source is connected in parallel with a short-circuited wire.
so if short circuit the system. Can I setup KCL on node A and then solve for I,
I = I(source) + I(R10).
But it seems odd to do so.
You got the equation wrong. It's IR10 = Isource + I. Be careful of the direction designated for Isc.
ok, got everything together now, ty for the help!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
