Calculating distance from redshift
  • Context: Undergrad
  • Thread starter Thread starter chris1969
    Redshift
The discussion revolves around the calculation of velocities of distant objects from their redshift, particularly in the context of Hubble's law. Participants explore the relationship between redshift and velocity, the implications of cosmological expansion, and the distinction between Doppler shifts and cosmological redshifts.
  • Some participants note that the velocity of distant objects is often not well-defined in cosmological contexts, typically represented as Hd, where H is the Hubble parameter and d is the comoving distance.
  • There is a distinction made between small Doppler shifts and cosmological redshifts, with the former being applicable to local motions and the latter related to the expansion of the universe.
  • A participant suggests using online calculators to determine distances based on redshift, highlighting that these tools can provide useful approximations.
  • One participant raises a question about whether Hubble's 1929 plot refers to velocity in a conventional sense or as a distance expansion rate, indicating a potential ambiguity in terminology.
  • Another participant discusses the challenges of defining velocity in cosmology, suggesting that for larger redshifts, it may be more appropriate to think in terms of distance expansion rates rather than conventional velocities.
  • A later reply references Bunn & Hogg's paper, which describes a method for defining recessional velocity through parallel transport of four-velocity vectors, raising further questions about the implications of this approach.
  • Concerns are expressed about the limitations of using simple flat maps to represent complex cosmological phenomena, emphasizing the need for careful consideration of the geometry involved.
Participants do not reach a consensus on the definitions and implications of velocity in cosmology, with multiple competing views and interpretations remaining throughout the discussion.
Limitations include the dependence on definitions of velocity and redshift, as well as the unresolved nature of mathematical steps in the discussion of recessional velocities.
This discussion may be of interest to those studying cosmology, astrophysics, or anyone looking to understand the complexities of redshift and its implications for the motion of distant objects in the universe.
chris1969
Hello everyone
I've starting to learn about Hubble's law and I have a very simple question. How are the velocities to distant objects calculated from a redshift? I understand the basic principle, that faster objects have longer wavelengths, but I'm not sure about the formula which links the two.
The wikipedia page has some formula for redshift, but the cosmological formula doesn't seem to have a term in velocity.
Many thanks in advance
Chris
Space news on Phys.org
chris1969 said:
Hello everyone
Chris
Right, that's because it's usually not considered in cosmological contexts, because the velocity of far-away objects is not well-defined. Usually it's just taken to be Hd, where H is the current Hubble parameter and d is the comoving distance.
chris1969 said:
How are the velocities [of] distant objects calculated from a redshift? I understand the basic principle, that faster objects have longer wavelengths, but I'm not sure about the formula which links the two.
Chris
For small local velocities a handy rule of thumb is simply that a Doppler shift of 1/1000 corresponds to radial (towards or away) speed of c/1000.
That is, about 300 km per second.
We distinguish between small DOPPLER shifts caused by small local motions, and COSMOLOGICAL REDSHIFTS caused by the expansion of the universe's geometry---the distance expansion rates---the rates we see large scale distances increasing without anybody actually getting anywhere.
Hubble law distance expansion rates are a different story from Doppler. You should probably get familiar with the convenient online calculators. For example, google "wright calculator" and put in a redshift, like 3, and press calculate.
It will give you a distance. Unfortunately it does not give a distance expansion rate, but you can calculate that yourself using Hubble law, if you want.
If you are interested in expansion rates, a handy shortcut is to use an online calculator with more features like where it says "...ocalc.2010.htm" in my signature. That one gives you the distance expansion rate too, as well as the distance itself.
Put in 3 for the redshift and it will tell you that the current recession rate is some multiple of the speed of light.
I just checked. The rate it gives is 1.53 c. About 53% faster than the speed of light.
Hubble law distance expansion rates should really not be called "velocities". It confuses people because it makes them think that geometry expansion is like ordinary motion (where you get somewhere).
In geometry expansion nobody gets anywhere---distances between everybody just get larger. Typically at rates faster than the speed of light. (The recession rate is proportional to distance and most objects we observe are far away enough that the distances to them are expanding faster than c.)
Many thanks both. I think I'm getting there, but I have a follow-up question if that is ok. Ned Wright's tutorial re-produces Hubble's 1929 plot of velocity against distance : does this refer to velocity as a layperson would conventionally understand it, or the distance expansion rate.
When we say the velocity of far away objects are not defined, does this mean that they could be moving quickly or slowly with respect to us? To put it another way, geometric expension increases with distance, but velocity needn't?
Many thanks once again
Chris
chris1969 said:
Ned Wright's tutorial re-produces Hubble's 1929 plot of velocity against distance : does this refer to velocity as a layperson would conventionally understand it, or the distance expansion rate...
For small distances it doesn't make any difference---you can think of it either way. And use either formula.
cosmologists' distance expansion redshift formula: 1+z = R(now)/R(then)
or
Doppler shift formula: z = v/c
Everything you do in cosmology involves fitting mathematical maps or models to nature and the fit is always approximate (even when amazingly good.)
So it's a bit like pasting flat maps over the surface of the earth. The fit is good if the chunk is small. VELOCITY as we usually think of it is defined in terms of some straight foursquare framework (not curved not expanding). The locally adequate "flat map" idea.
If you take too big a chunk of spacetime a simple framework won't accurately encompass/represent the whole thing.
Two things with the same velocity (same speed and direction) might eventually crash, or veer widely apart. Curvature is bad enough but expanding geometry (a kind of curvature in 4D) makes it even worse.
Simple flat rectilinear coordinate maps don't fit when you try to cover large distances and timespans. So good local concepts like VELOCITY become problematical.
So one rule of thumb might be that for redshifts z > 0.01 try to think in terms of "distance expansion rate" and use the formula 1+z = R(now)/R(then).
But for redshifts z = 0.01 that would only correspond, if it were a Doppler effect of ordinary motion, to one percent of the speed of light: 3000 kilometers per second. So if you like, think of it as a Doppler shift! And the distances and times involved would be comparatively small. The Hubble expansion rate changes over time, but only slowly. So over short intervals of time (cosmologically speaking) it is a constant "the Hubble constant".
It's just an arbitrary rule of thumb but it might help resolve things for you.
marcus said:
... Everything you do in cosmology involves fitting mathematical maps or models to nature and the fit is always approximate (even when amazingly good.)
So it's a bit like pasting flat maps over the surface of the earth. ...
Marcus, This is the first time that I have heard this described in this fashion. It does make a lot of sense, but can I ask it is intended to be taken literally or is it more of a reflection on margins of error with variables / measurements?
Regards,
Noel.
I found Bunn & Hogg's paper very helpful in coming to a sort of understanding of this issue.
In section III they describe how the recessional velocity can be meaningfully defined by parallel transporting the four-velocity vector of the distant galaxy, at the time it emits the light we see now, along a geodesic to the observer's current spacetime event. We then measure the recessional velocity as vrel = sqrt(1-1/g(vob,vem)2), where vob and vem are the observer's current four-velocity and the emitter's parallel transported four-velocity respectively.
Bunn and Hogg claim that if the geodesic along which we parallel transport is the lightlike geodesic that the light we see follows then the formula gives us a recessional velocity that gives the observed redshift when plugged into the SR Doppler redshift formula. I wonder whether this is the recessional velocity usually intended when physicists refer to recessional velocities.
I have been wondering what would happen if we instead parallel transported the emitter's four-velocity at the current cosmic time, along a spacelike geodesic, to our current spacetime event. Would that be the best way to define a "current" recessional velocity? And would the value be uniquely defined, ie would there be only one such spacelike geodesic in a LDCM universe?
  • · Replies 44 ·
  • · Replies 28 ·
  • · Replies 55 ·
11K
  • · Replies 23 ·
