Calculating Earth's Orientation and Moon's Position at J2000.0
The discussion revolves around calculating the Earth's orientation and the Moon's position at the epoch J2000.0, focusing on the reference orientation of Earth with respect to the Sun and Moon. It includes considerations of time conversion and accuracy in modeling an Earth-Moon-Sun system.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant seeks calculations for Earth's orientation and the Moon's position at J2000.0, specifically asking which longitudinal line of Earth faces the Sun and where the Moon is positioned relative to that line.
  • Another participant notes that J2000.0 is defined at noon Universal Time, indicating that longitude 0 degrees is facing the Sun, but raises the issue of the difference between Universal Time and Terrestrial Time.
  • A participant questions the necessity of high accuracy, suggesting that a simple conversion from UT to TT could suffice and that an accuracy within one degree is acceptable.
  • There is a reference to the JPL Horizons website as a resource for obtaining the position of solar system objects at any given time.
  • Some participants discuss the minor difference in time between UT and TT, with one suggesting that the difference is small enough not to be a concern for their level of accuracy.
Participants express varying levels of concern regarding the accuracy of time conversion and its impact on calculations, with some suggesting that a degree of inaccuracy is acceptable. There is no consensus on the necessity of high precision in the calculations.
The discussion includes assumptions about the relevance of time conversion and the implications of accuracy on the modeling process, but these assumptions are not fully explored or resolved.
Individuals interested in astronomical modeling, particularly those working with Earth-Moon-Sun systems or seeking to understand the implications of time conversion in celestial mechanics.
TheGalaxyOfGold
Hi there,
I am making a very basic model of an earth, moon, sun system in ECEF in C# using the Helix Toolkit and in order to begin transformations according to Earth's rotation, tilt, and orbit, I need a reference orientation/position/time of Earth with respect to the sun and moon.
So my question is, where can I acquire calculations for the orientation of Earth at J2000.0 as well as the position of the moon with respect to Earth at this same epoch. For instance, which of Earth's longitudinal lines is most-directly facing toward the sun at J2000.0 and given that orientation, on which of these longitudinal lines belonging to Earth is the moon most closely sitting directly over?
Astronomy news on Phys.org
How accurate do you want to be? Since J2000.0 is defined at noon Universal Time, longitude 0 degrees is facing the sun. However, this is not quite true because of the difference between Universal Time and Terrestrial Time. How deeply do you want to get into these issues?
As for the position of the moon, the JPL Horizons web site will give you the position of any solar system object at any time.
I could just convert from UT to TT with a simple conversion equation, can't I?
I don't think accuracy is imperative, as long as its accurate too within a degree I should be fine.
I think so. This Wikipedia site says the difference is only 64 seconds ( about .25 degrees), so if one degree is your level of accuracy I just wouldn't worry about it.
thank you very much sir!
  • · Replies 33 ·
  • · Replies 98 ·
12K
  • · Replies 17 ·
