Calculating Electron Density in F2 Layer Using Ionosonde Pulse
The discussion focuses on calculating electron density in the F2 layer using an ionosonde pulse. The electron density at heights below 300 km can be expressed using a scale height relationship involving neutral atomic oxygen. A critical frequency formula is proposed to relate the ionosonde pulse to electron density, emphasizing that the F2 region typically operates within 3-30 MHz. The wave's reflection point indicates the electron density at that height, and the plasma frequency is directly linked to electron density. Understanding these relationships is crucial for accurate calculations in ionospheric studies.
stunner5000pt
The electron densities, ne, at any height h < 300 km on the lower side of an F2 layer can be described by a scale height relationship:
n_{e}(h) = n_{e}(300) \exp\left(\frac{0.75(h-300)}{H_{O}}\right)
where HO is the neutral atomic oxygen scale height. If the ionosphere has an isothermal temperature of 1500 K and a 9 MHz ionosonde pulse is reflected from 200 km, calculate the electron density at 300 km. [Magnetic field effects may be ignored and you may assume that we only have an F2 layer]
i can easily calculate the scale height Ho. The problem is... how does the EM pulse relate to the density of electrons in the atmosphere?
am i missing something... some formula that sohuld be used?
should it be
f = 9 \times 10^{-3} \sqrt{N_{e}}
where Ne is the density of electrons in the atmosphere (F2 region)? That represents a critical frequency. Typically teh F2 region's threshold is 3-30 Mhz isn't it ?
your help is greatly appreciated! Thank you
For normal incidence into the F2 layer the wave will obey
\frac {\partial^2 E}{\partial z^2} + \frac {\omega^2 - \omega_p^2}{c^2} E = 0
where \omega_p is the plasma frequency (proportional to \sqrt {N_e}). This tells you the wave turns around at z such that
\omega_p^2(z) = \omega^2
You were also given that the height at which the wave reflects and you can infer the density at that point. You should be able to handle the rest.
i am not familiar with the that differential equation i don't think we were supposed to use it but...
do i solve for E? WHat is omega? Is it the frequency of the wave which we sent, so that is a constant as well? So do i solve that differntial equation?
i,m not quite sure how the height of the reflection says anything aobut hte elctron density...
No, you don't have to solve for E. The equation was just to demonstrate that the light wave reflects off of what is called the "critical surface," i.e. where the (fixed) radio wave frequency \omega is equal to the plasma frequency \omega_p.
The plasma frequency is related to the electron density:
\omega_p = \frac {4 \pi n_e e^2}{m_e}
(in cgs units - look it up for the units you need) so the plasma frequency varies with height since the electron density varies with height.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
