How Do You Calculate the Empirical Formula from Element Percentages?
  • Thread starter Thread starter jais
    Formula
To calculate the empirical formula from element percentages, divide the percentage of each element by its respective atomic mass. This gives the number of moles for each element. Next, find the simplest whole number ratio of these mole values. For example, if you have three elements, perform these calculations for each to derive the empirical formula. This method effectively determines the compound's empirical formula based on its elemental composition.
jais
If i have percenteges of three elements, making up a compound, how do i Calculate the molecular formula or empirical formula of the compound? Can someone give me an example?
to calculate the empirical formula,u have to divide the % with the elements respective Ar then find the simple ratio.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
