Calculating Enthalpy Change in Reactions Using HCl or NaOH - Step-by-Step Guide
  • Thread starter Thread starter NickP717
    Change
To calculate the enthalpy change (Delta H) for the reactions involving HCl and NaOH, the temperature changes before and after mixing the solutions are crucial. For the first reaction, the temperature rose from 22.6°C to 35.7°C, leading to a calculated Delta H of 13.13 kJ/mol for HCl. The second reaction showed minimal temperature change, indicating little to no heat evolved. The third reaction resulted in a temperature increase from 22.4°C to 31.7°C, which also contributes to the overall enthalpy calculations. Accurate calculations rely on using the mass of the solutions, specific heat of water, and the temperature change to determine heat evolved.
NickP717
The problem says: Enthalpy is always reported with respect to a reactant. Calculate the enthalpy change, DeltaH, for each reaction in terms of kJ/mol for one of the reactants. (i.e either HCL or NaOH).
I had three reactions:
1. NaOH + HCL---->H20 +NaCl
2.NH4Cl +NaOH---->H20 +NH3 +NaCl
3. HCl +NH3---->NH4
The first reaction I measured out 25.3mL of 2.0M HCl into a foam cup, then I dumped in 25.4mL of NaOH solution into the cup... my lowest temperature was 22.6 degrees C (before two solutions re combined., and my highest was 35.7 degrees C (when the solutions were mixed).
The second reaction I measured 25mL of 2.0M NaOH into a foam cup and then dumped 25.4mL of 2.0M NH4Cl solution. My lowest temperature was 22.5 degrees C (before mixing), and highest was 23.8 degrees C (after mixing).
The third reaction I measured 25.3mL of 2.0M HCl into a foam cup and then dumped 25.5 mL of 2.0M NH3 solution. My lowest temperature was 22.4 degrees C (before mixing), and highest was 31. 7 degrees C (after mixing thr two solutions.
Can somebody help me and show me what to do possibly, I really have no clue. Thank you so much!
How much heat evolved in each case?
I would do it by working out the total amount of temperature rise over the whole reaction mixture (which you have been given), and then assume that the density of the two solutions is still 1.00 g/cc (which they will be, as near as makes no odds).
The delta H will then be:
Delta H = m.c.t
where m is the mass of the two solutions (technically the mass of the WATER in the two solutions but it's as near as makes no odds, as I said above), c is the specific heat of water, which is 4.2 J/g, and t is the temperature change.
First, work out the number of moles of HCl that you have used. This will be equal to 25.3/1000 x 2 = 0.0506 moles.
Now do the delta H calculation:
Delta H = (25.3+25.4) x 4.2 x 13.1 = 664.17 J
Therefore, 0.0506 M gives 664.17 J.
So, per mole (of HCl) it works out at (1/0.0506) x 664.17 = 13,125.89 J
So delta H wrt HCl is 13.13 kJ/mol.
Thats how I'd do it...but since I haven't done these for about 25 years I may be wrong ! :smile:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
