cjc0117
- 94
- 1
If you know the resistance coefficient, K, for a sudden expansion or contraction in a pipe, how can you calculate the equivalent length, Le from the K value?
I know that for fittings, Le=KD/f, where D is the diameter and f is the Darcy friction factor. But when considering a contraction or expansion with a known K value, should you use the diameter of the larger or smaller pipe when calculating Le? And which pipe's friction factor should be used? Do you use averages, perhaps? Thanks
