Calculating Frequency for AC Waveforms
  • Thread starter Thread starter daveiejbeer
    Frequency
To calculate the frequency of AC waveforms, first convert the time from milliseconds to seconds. The frequency can be determined using the formula f = number of cycles / time in seconds. For the given examples, the first waveform completing 4 cycles in 5 ms results in a frequency of 800 Hz, while the second waveform completing 5 cycles in 8 ms results in a frequency of 625 Hz. It's important to remember that frequency is typically expressed in Hertz (Hz). Proper unit conversion is crucial for accurate calculations.
daveiejbeer
Hello my mind has gone blanc whilst in the middle of my AC Theory assignment.
The question is:
Calculate the frequencies for the following wave forms:
i. An alternating current that completes 4 cycles in 5ms
ii. An alternating current that completes 5 cycles in 8ms.
Am I right in thinking work out how many ms to complete 1 cycle then work out using f = 1/T
Can anyone point me in the right direction?
Dave
Welcome to PF!
Hello Dave! Welcome to PF! :wink:
Yup! :biggrin:
Well … sort-of … if it's 1 cycle in T milliseconds, then it's 1000 cycles in T seconds, so it's … ? :smile:
frequency is usually in Hz so you need first to convert the time from ms to s .. the second thing is that what you are thinking is right,but there is an even easier direct way .. Why just don't you say that the frequency (f) = no. Of cycles / time .. :) then you will have the problem done..
Hi daveiejbeer, welcome to PF.
Frequency f = no. of cycles per second.
In the first case convert ms to s and find f.
Thanx for your help. I have already worked out the answers but I wasn't converting it into seconds, Doh!
Thanx once again.
Dave
