Calculating Internal Resistance: Methods A and B
The discussion revolves around calculating the internal resistance of a battery using two different methods, A and B, involving measurements from a voltmeter and ammeter. Participants are exploring the implications of their measurements and the application of Ohm's Law and Kirchhoff's laws in their calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the division of current in Method A and the relationships between various resistances. Questions arise about the validity of using Ohm's Law directly and the implications of internal resistances of the measuring devices. There is exploration of equivalent resistances in parallel and series configurations.
Some participants have provided guidance on considering internal resistances and applying Kirchhoff's laws, while others express confusion and seek clarification on specific points. The discussion is ongoing with multiple interpretations being explored.
There is a noted complexity due to the presence of multiple unknowns and the internal resistances of the voltmeter and ammeter, which are under discussion but not fully resolved.
Adriano25
[/B]
Calculate the internal resistance of V & A based on methods A & B below:
Method A
Voltmeter = 1.46 V
Ammeter = 0.24 A
E (emf of battery) = 1.48 V
Method B
Voltmeter = 1.48 V
Ammeter = 0.24 A
Ohm's Law: V = I*R
For method A, the current of the ammeter (II) splits into Iv (current of voltmeter) and IRX (current of unknown resistor). Also there will be an unknown resistance of voltmeter (RV) and an unknown resistance of ammeter (RI).
I found a relationship using Kirchhoff's current law:
II = IV + IRX
Then, I tried to use Kirchhoff's voltage law through both loops, but I'm ending up with too many unknowns. Am I going on the right path?
Also, I'm not sure if I could find the unknown Rx by just using Ohm's Law:
Method A:
Rx = V / I
Rx = 1.46 V / 0.24 A = 6.08 Ω
Method B:
Rx = V / I
Rx = 1.48 V / 0.24 A = 6.17 Ω
Adriano25 said:
[/B]
Method A
Voltmeter = 1.46 V
Ammeter = 0.24 A
Method B
Voltmeter = 1.48 V
Ammeter = 0.24 A
Ohm's Law: V = I*R
II = IV + IRX
Method A:
Rx = V / I
Method B:
Rx = V / I
No, your simple method is not correct. You have to calculate with the internal resistances, Rv and Ri. Include them into the drawings, Rv parallel with the voltmeter and Ri in series with the ammeter.
From method 1, would that mean that I can find an equivalent resistance from Rv and Rx using the parallel circuit formula?
Also, from method 2, I could find an equivalent resistance from Ri and Rx using the series circuit formula?
I'm still not sure how that would help me in solving the problem.
Yes.
In case A, the voltage difference E-Uv falls on the internal resistance of the ammeter. You know also the current flowing through Ri, so you can calculate it. In case B, you know the voltage across Rx+Rv, and you also know the current. Apply Ohm's Law to get Rx+Ri. But you know Ri already...
ehild said:
Yes.
I'm sorry, I don't follow you. Could you please reexplain it? Thank you.
What is that you do not understand?
Look at the figure A. The meters are replaced by ideal ones, together with the internal resistances. The EMF of the (ideal) battery is 1.48 V, and the voltmeter reads 1.46 V. What is the potential difference between P and O?
The potential difference between P and O would be V = Ii * Ri
Yes, and what is the numerical value?
But we don't know Ri.
I was thinking that since Rx and Rv are in parallel, they share the same voltage, so V1 = 1.46.
Then, using Kirchhoff's voltage law:
-V1 * Ii - Ri * Ii + E = 0
so, Ri = 4.7 Ω ?
so, Ri = 4.7 Ω ?
V1*Ii is not voltage, you can not add it to voltages.
Ups..
-Rx*Ii - Ri * Ii + E = 0
Ri = 0.04 Ω
Adriano25 said:
Ups..
Ri = 0.04 Ω
No. Rx and Ri are not in series, they have different currents.
You know the KVL. The voltages add in a loop. The voltage between Q and P is shown by the voltmeter, it is 1.46 V. The voltage between Q and O is the same as the emf of the battery. What is the numerical value of the voltage between P and O?
Then it would just be the difference between QO and QP, so the voltage between P and O would be 0.02 V?
YES!
