Calculating Linear and Centripetal Acceleration for a Car in Rotational Motion
To calculate the linear speed of a car in rotational motion, the formula used is linear speed equals the radius multiplied by angular speed, resulting in 30 m/s. The centripetal acceleration is determined using the formula rw², yielding a value of 18 m/s². The linear acceleration, calculated as r multiplied by angular acceleration, is 10 m/s². The total linear acceleration combines both components, resulting in approximately 20.6 m/s². Understanding the vector nature of acceleration is crucial for accurately determining the total acceleration in different directions.
pb23me
At a particular moment in a race, a car moving around a turn with a radius of 50m had an angular speed of .6rad/sec and an angular acceleration of .2rad/sec2
At this particular moment find:
the linear speed
the centripetal acceleration
its total linear acceleration
w=\Deltatheta/\Deltat
vt=rw
alpha=\Deltaw/\Deltat
linearspeed =50*.6=30m/s
linear acceleration would be at=r(alpha) so at=10m/s2
I don't know how to calculate the centripetal acceleration
You probably have a formula for centripetal acceleration in your book or notes. This is one of those "given" formulas that you learn (on par with F=m.a in freshman physics). Your other problem is, what do you really mean by "linear acceleration"? Acceleration, like velocity, has a magnitude and direction, i.e. it is a vector. As a vector, it can be broken into components and there is some "resultant" or "total" acceleration. Hint: what is the relationship between the "centripetal" direction, and the direction that you have indicated with a subscript "t"? Identify the components of the acceleration in an appropriate coordinate system.
ok so centripetal acceleration=rw2=18m/s2
i know that centripetal acceleration points towards the center of the circle and linear acceleration is tangential to the circle... i don't know what direction to break linear acceleration up into..
well i just looked at the drawing and it seems to indicate that there is an acceleration 45 degrees inward from at
102+182=424 so total linear acceleration=20.6m/s2
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
