Calculating mass of air from Speed and Density?
To calculate the mass of air moved downwards by a hovering helicopter, the area of the blades is crucial, which is given as 1.5 m². The density of air is 1.2 kg/m³, enabling the calculation of mass per second by multiplying the volume of air displaced (6 m³) by its density. The discussion also raises questions about the change in momentum, specifically whether it refers to the helicopter or the air itself. Clarification is needed regarding the momentum calculation, as it depends on the context of the question. Overall, understanding the area and the displacement of air is essential for accurate calculations.
ntk_k
For the hovering helicopter, it is assumed that all the air beneath the blades is pushed vertically downwards with the same speed of 4.0m/s. No other air is disturbed.
The density of air is 1.2kg m^-3
How can you calculate, for the air moved downwards by the rotating blades,
i) the mass per second
ii) the rate of change in momentum ??
You can't unless you know the area of the blades. Do you?
The length of each blade of the helicopter is 0.70m. The area that the blades sweep out as they rotate is 1.5 m^2.
could you not just calculate the area of the cylinder? which would be an area of 6m^3. then find out the mass of the air in the 6m^3. I believe that would be the mass per second.
As for the change in momentum, I am unclear as to what the question is asking. Are you asking for the change in momentum of the helicopter? Or the change in momentum of the air?
in case of any ambiguity, the 6m^3 arises from 1.5m^2(area of the blades), multiplied by the metres of air displaced in one second.(4m)
ii) the rate of change in momentum ??[i don't know]
ideasrule said:
You can't unless you know the area of the blades. Do you? the area = 85.9645m^2
kabwe said:
ideasrule said:
You can't unless you know the area of the blades. Do you? [yes area = 85.9645m^2]
