How Much Force to Pull a 1 Tonne Rock Up a 30 Degree Slope?
  • Thread starter Thread starter vbillej
    Force Minimum
To calculate the minimum force needed to drag a 1-tonne rock up a 30-degree slope with a resistance of 350N, one must consider the forces acting on the rock, including gravity, normal force, friction, and the force from the pulley system. The weight of the rock is 9800N, which is the gravitational force acting on it. A free body diagram is recommended to visualize these forces and determine the necessary calculations. The discussion emphasizes the importance of accurately identifying and accounting for all forces involved in the scenario. Understanding these principles is crucial for solving the problem effectively.
vbillej
1. A 1 tonne rock is being dragged up a 30 degree slope using the a pulley system.
If there is a constant resistance to movement between the rock and the ground of 350N, calculate the minimum force necessary to drag the rock up the slope.
2.
3. All i got so far is
1t = 1000kg
1000kg x 9.8 (gravity)
=9800N
Acting upon the slope from the rock
Set up a free body diagram to find the forces acting on the rock.
Thanks
Matt
Hi vbillej! :smile:
1t = 1000kg
=9800N
No, that's wrong …
9800N is the force of gravity on the rock.
There are four forces on the rock … gravity, normal force, friction force (= 350N), and the force from the rope.
As CFDFEAGURU :smile: says, set up a free body diagram.
Thanks both of you for your replies
tiny-tim said:
Hi vbillej! :smile:
Yes i forgot its actually the weight from the rock, thanks for reminding me
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
