Calculating Moment and Deflection for Handrail Beam with Attached Bolt
  • Thread starter Thread starter blackbird2552
    Beam
The discussion focuses on calculating the moment and deflection for a handrail beam measuring 4" x 4" that is supported by a bolt at the bottom. The user inquires whether to use the full 89 mm or half (89/2) in their calculations for section modulus and moment of inertia. The consensus is to use 51 mm (89 mm - 38 mm) for both calculations, as the remaining portion of the beam has minimal impact on deflection. This clarification aids in accurately determining the bending stress and deflection of the handrail beam.
  • Understanding of section modulus calculations
  • Knowledge of moment of inertia in beam theory
  • Familiarity with bending stress concepts
  • Basic principles of structural engineering
  • Research "Calculating Section Modulus for Beams"
  • Study "Moment of Inertia for Rectangular Sections"
  • Explore "Bending Stress in Structural Beams"
  • Learn about "Deflection Limits in Structural Design"
Structural engineers, civil engineering students, and professionals involved in beam design and analysis will benefit from this discussion.
blackbird2552
Hello everyone,
I have a question regarding the moment and deflection calculation of this handrail beam that I have. I am attaching a picture to give you guys a look at what I am working with.
The hand railing is 4" x 4" and it is not attached half way, its just resting on that beam, it is however attached with a bolt at the bottom. My question is, when I am looking for the resisting moment would I take 89/2 in the section modulus calculations or the full 89mm. Same goes for deflection, when I do the moment of inertia, would I do the full 89 mm or 89/2. If it is 89/2 then how would I incorporate the rest of the beam in the resisting moment/deflection or would it have no effect on it?
any help would be greatly appreciated, thanks!
http://tinypic.com/r/lzmh2/6
blackbird2552: In general, it appears you would use (89 - 38) = 51 mm, and 0.5*51, in the section modulus calculation, for the bending stress calculation. You would also use 51 mm in the moment of inertia calculation, for the deflection calculation. The 89 mm portion of the handrail beam would have little or no effect on the deflection.
Thank you so much! that is exactly what i needed confirmed and also thanks for clearing up my concept.
  • · Replies 16 ·
