Orbital Velocity Calculation for an Asteroid at Perihelion
To calculate the orbital velocity of an asteroid at perihelion, the formula Vp = {GM/a ((1+e)/(1-e))}^0.5 is used, where G is the gravitational constant (6.67x10^-11 m^3 kg^-1 s^-2) and M is the mass of the Sun (1.988x10^30 kg). The variable 'a' represents the mean distance of the asteroid from the Sun, which should be in meters for the result to be in m/s. It's important to maintain consistent units throughout the calculation to avoid errors. Using meters for distance and kilograms for mass will yield the correct orbital velocity.
ZedCar
If calculating the orbital velocity of an asteroid at perihelion I use:
Is the G the gravitational constant G = 6.67x10^-11
Is M the mass of the sun = 1.988x10^30 kg
Is 'a' the mean distance of the asteroid from the Sun in metres/km/AU ?
Thank you.
Is M the mass of the sun = 3.518 x 10^8 kg
Choose meters if you want the result in m/s, and use M in kg and G in m3kg-1s-2. Otherwise you'll have to fiddle with the units of GM to match your choice if length unit.
