Calculating Power Factor in an AC circuit, given voltage and current
5 replies · 2K views
bardia sepehrnia
Poster has been reminded to post schoolwork in the Homework Help forums
Calculate the power factor for each case:
v(t) = 540 cos(ωt + 15◦) V, i(t) = 2 cos(ωt + 47◦) A
v(t) = 155 cos(ωt − 15◦) V, i(t) = 2 cos(ωt − 22◦) A
Vrms=V/sqrt(2)
Irms=I/sqrt(2)
My attempt at solving this question:
I realized my attempt is wrong however I just don't know how to proceed in the first step. How can I calculate the phase shift? and find Voltage and Current in phasor form??If I know that, then I can use power factor formula: pf=Pav/V*I
The plane in which voltages and currents are represented rotates with ω radians per seconds. The angles between voltages and currents are constant and rotate all the time with the same velocity. Power factor it is the cos(ϕ).
Yeah, I realized I just had to subtract the voltage angle from the current one and take cosine of that. Thank you.
can you also help me with this one pls?
I understand that the first 2 are capacitive as power factors are leading. In C, I think I understand why it's inductive because first if we change current equation to cosine, then: i(t)=4.2 sin(ωt-(pi/2)), and the phase angle is 0-(-pi/2)=pi/2, and positive phase angle indicates that the load is inductive. If that reasoning is true, then d, should i also be inductive, but it is resistive. I thought the phase angle has to be for the load to be resistive.
You are right.
