Calculating Radioactive Au(A=198) and Hg(A=198) After 5 Days of Bombardment
  • Thread starter Thread starter shahar weiss
    Decay
shahar weiss
Here's a ques. I am having problem with:
sample of gold is bombard with 2*10^10 neutrons per sec. it cause the Au(A=197) become radioactive (Au(A=198)) which decay with half life time of 2.969day (through beta decay
1. how many Au(A=198) will be after 5 days of bombardment?
2. how many Hg(A=198) will there be after 5 days?
3. what is the number of radioactive Au(A=198) at equilibrium and what will be the activity of the sample?
im having problem getting the differential equations right here, ill be very happy for any help. thank you so much in advance
Have you tried with
?R.
Welcome to physics forums.
Okay, there are two things to think about here concerning the Au-198:
  • At what rate are Au-198 atoms created?
  • At what rate are Au-198 atoms destroyed (i.e they decay)?
Those two rates determine what \frac{dN}{dt} is for Au-198.
Rick88 said:
Have you tried with
R.
wont work here since there are two different half life times, two different activities, two different decay constants.
your formula is good when there is simple decay from some amount of radiactive sample.
here the sample's size changing all the time
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
