Calculating Solar Energy Generation from GHI, DNI, and DHI Data
The discussion focuses on calculating the daily energy generation of a 20 kW solar power system using hourly meteorological data, including Global Horizontal Irradiation (GHI), Direct Normal Irradiation (DNI), and Diffuse Horizontal Irradiation (DHI). The participants emphasize the importance of understanding how to apply these values to determine insolation and yield factors, with a suggested yield factor of 0.89 for efficiency. There is also mention of using data from the NREL website and NASA for accurate insolation calculations based on specific geographic coordinates. The conversation highlights the potential energy output and financial implications based on calculated kWh generation. Accurate calculations can lead to better estimations of energy production and savings.
athar.walile
Can we calculate the daily energy generation of 20KW power pack if have the following information:
Date Time GHI DNI DHI
01-01-2008 08:00 0 0 0
01-01-2008 09:00 149 398 75
01-01-2008 10:00 348 686 98
01-01-2008 11:00 512 792 112
01-01-2008 12:00 626 845 119
01-01-2008 13:00 674 859 123
01-01-2008 14:00 659 860 119
01-01-2008 15:00 574 827 112
01-01-2008 16:00 431 753 100
01-01-2008 17:00 245 497 106
01-01-2008 18:00 36 63 30
01-01-2008 19:00 0 0 0
Thank you.
Thank you.
What is the context of the question? Can you please provide more details? Is this question for schoolwork?
Based on in information i have,
Location of Project : Latitude- 26.9° N, Longitude- 72.0° E
Size of Project : 20 KW
Hourly Meteorological Data : Global Horizontal Irradiation, Direct Normal Irradiation, Diffuse Horizontal Irradiation
I want to find out the possible generation of energy for that plant in KW. I have provided the hourly based meteo data.
Here is the solution
Total generation of units (kWh) = Insolation factor x Yield Factor x Total installed capacity
Are your panels fixed? What is their orientation?
How are you using the GHI, DNI and DHI to arrive at a value of Insolation, and is this data your own?
Can you expand upon what Yield Factor incorporates?
Yield factor is 0.89
Little confused about using GHI, DNI and DHI values in my insulation calc. but i m using GHI in my calculation. I am not aware of how to use meteorological data here.
I got this data from NREL website: http://rredc.nrel.gov/solar/new_data/India/nearestcell.cgi?
Find out your Latitude & Longitude:
http://www.whatsmygps.com/"
Find your Insolation:
http://eosweb.larc.nasa.gov/cgi-bin/sse/grid.cgi?email"
  1. Sign up (its free)
  2. Enter your Latitude & Longitude
  3. Select the data you want ('Average Insolation' only will suffice)
You now have your average monthly Insolation.
Alternatively you can calculate the contribution from GHI, DNI and DHI to your Hourly Insolation relative to the orientation of your solar panel(s) and get much more accurate specific site data, but if you don't need it, the NASA information is a good enough approximation.
So if you have a 2kW system, and have 5 Hours Insolation, you can expect to get (2kW * 5H =) 10kWH from your system that day.
I assume the Yield Factor is an expression of efficiency, so at 89% you would end up with (10kWH * 0.89 =) 8.9kWH instead.
At $0.20 per kWH you would have made/saved (8.9kWH * $0.20 =) $1.78 that day!
