Calculating the force required to generate 100 kilowatt per hour
  • Context: Undergrad
  • Thread starter Thread starter Jaxodius
    Force Per
The discussion revolves around calculating the physical force required at a specific point to generate 100 kilowatts of power using a mechanical system involving gears and an alternator. Participants explore the relationship between power, force, and rotational speed, while addressing misconceptions about units of power and energy.
  • One participant seeks to understand how much force is needed at point B to generate 100 kW, given a gear system that increases RPM at point A.
  • Another participant emphasizes the need for a specific rotational speed to calculate the required force, providing an example calculation based on 1 revolution per second.
  • Confusion arises regarding the correct interpretation of power and energy units, with one participant mistakenly using terms like "kilowatts per hour."
  • Participants discuss the implications of using different gear ratios and how they affect the force and power output, with one suggesting a complex gear setup to manage force application over time.
  • Clarifications are made about the difference between power (watts) and energy (joules), with participants attempting to reconcile their understanding of these concepts.
  • One participant expresses a desire to conduct practical experiments based on their calculations, while another warns about the importance of understanding the correct units of measurement.
There is no consensus on the correct understanding of power and energy units, with multiple participants expressing confusion. Some participants agree on the need for clarity in definitions, while others continue to struggle with the concepts.
Participants highlight limitations in their understanding of the relationship between power, force, and energy, as well as the importance of using appropriate units in calculations. The discussion reflects varying levels of familiarity with these concepts.
This discussion may be useful for individuals interested in mechanical systems, energy generation, and the principles of power and force in physics.
  • #31
DaleSpam said:
This is completely silly...
Jaxodius said:
... Therefore :
3600 rpm * 60 = 216000 rpm . If i used 6 gears with ratio of 15:1 between 5 of them and 5:1 between 1 of them making it a total of 253125:1 ...
This is completely impractical as well.
  • #32
Jaxodius - The oven will probably only use 100kW when the element is actually on. Once upto temperature the thermostat will turn the element on and off so that the average power supplied matches the losses through the walls of the oven. So your first priority should be to determin actual power consumption and reduces losses by insulating the oven as much as possible. Once upto temperature the losses might be a lot less than 100kW?
  • #33
Dale you said:
This is completely silly. If it made any kind of economic sense to generate power this way then power companies would be generating it this way.
i understand that you and others here think that the whole thing is silly. i understand that all the power companies in the world think it is silly too. that is ok. i still want to try it out and i need some help with the maths of it all. maybe the first day i try it out it will all just go poof in my face. and that is fine too. but i still want to try it out.
Can you please clarify how? i have asked this question in my previous posts as well but i was told by one user that i should not worry about the gears but the force being applied.
The oven will already be insulated. so i am not too concerned with that at the moment. i just want to be able to get to a point where i can atleast make an attempt at something like this.
russ you said:
24 hours? 8 hours?
yes for me it is acceptable if 1/3 of the whole day is lost as long as i have that power by the end of that 8 hours to discharge for 3 hours every day.
1. How are you going to store the energy if the oven is only running for 3 hours?
from post # 25 :
Infact, as the discussions have progressed, something else comes to mind. what if the 250w per person was directed to raise an object which was 5000 kg / m3, such as hematite ( iron ore which is 5095 kg/m3 ) and had 10 m3 of it raised to 100 meters ( it does not strictly have to be raised above ground, it could just as well be pulled up from a shaft dug 100m into the ground. This is the calculation i made. please tell me if it is wrong:
10 m3 blocks of hematite ( 1 on top of another ) = 50000 kg m3
(so 50000 (weight) * .028 m/s (to allow the blocks to fall in 1 hour as 100 meter / 3600 seconds ) * 100 (height)) / 1000 (to convert it into kw ) = 140 kw-s.
is the maths correct here?
  • #34
Before you put an advert on Craigslist for 400 people to push your oven, you really should be sure you've got something vaguely correct.
Read the label on your oven. Does it really say 100 kW? The electric circuit on a house is typically not bigger than 200 amps. At 240 volts and 200 amps that's only 48 kW. So you've got something more than twice the power of a fairly hefty house electric service. Whatever are you putting in there? Are you sure it isn't 10kW?
If you are using 400 people that's about 250 watts per person. That's a respectable amount of power to expect a person to continue to put out for three hours, even if they can do it at their most efficient output level.
If you are turning an electric generator, you need to consider efficiency of the generator. Often they are only about 30% efficient. That means, if you put 100 watts of work in, you get only about 30 watts of power out. The rest goes to heating the generator. So you won't need 400 people you will need 1330.
A 100 kW generator is pretty big. Probably need at least a pickup truck to carry it.
This entire project is sounding pretty silly.
  • #35
Jaxodius said:
The reason why we think it is silly is because the only way you could have a net gain of energy is if you have slave labor that you are literally starving to death. Exerting 250 W for 3 hours is 2,700,000 J of energy. In food terms, this is 650 kcal per person, or about 1 hamburger. So let me get this straight - you are going to hire 1000 people and buy them 1000 hamburgers so you can run an oven for 3 hours? Why not just take the 1000 hamburgers and burn them in a furnace? You'd get more heat energy that way compared to all the losses due to human metabolism losses and generator efficiency losses in your scheme.
  • #36
[One watt is the rate at which work is done when an object's velocity is held constant at one meter per second against constant opposing force of one Newton.
The unit, defined as one joule per second, measures the rate of energy conversion or transfer.] From Wiki-media.
So I was thinking in mechanical perspectives. If I have two objects both massing the same, say 5 kg. One is at rest, the other is in motion on a trajectory that will cause it to strike the stationary object. The surface(s) that impact will be considered to be flat, have the same area, and be parallel, and aligned, when they strike. No application of resistance, or opposition will be considered. If the moving object is moving at one meter per second, when it impacts the stationary object, it will cease moving, and the impacted object will begin moving at one meter per second. Please correct this statement if not correct.
I realize that in the definition from wiki, the opposition of one Newton is integral in the definition. Yet since the opposing force; the stationary object; equates with the moving object, I believe this accounts for the force in my textual description
Jeffrey.
  • #37
Jeffrey.
If the objects are perfectly elastic, all the momentum of the moving one will transfer to the originally stationary one (they 'exchange' momentum). If they coalesc, then they will move off together at half velocity and half of the original Kinetic Energy is lost. Momentum is always conserved but the kinetic energy is not, except for elastic collisions. In your scenario, and in nearly all collision problems, it is not a good idea to try to consider 'forces' when all you want to know is the before and after situations. This is because there are a whole lot of possible forces which will provide the same end result (depending upon the elastic constants of the objects). It's better to use the Momentum approach, which doesn't need that sort of detail but still gives the answer.
  • #38
I see what you mean, after reviewing the terms of 'elastic' and 'coalesc', I realized it was not right to ignore the properties of the two objects, in question. As, in the case of two rubber masses, as compared to two steel bearings. They both bounce, yet the steal bearing, even with being extremely hard and not as easily seen as elastic, would transfer its' momentum in a manner which would transfer more of the kinetic energy of the moving one, to its' counterpart, while two rubber balls would deform more, so there would be a slower transfer of kinetic energy, which would provide more coalesc-ing; which would transfer less of the moving objects inertia, to the stationary object. At least that is what I understood about your discussion, and review of the terms you used.
  • #39
is the maths correct here? how would i calculate how long it would take for that load to be raised up to 100 meters?
  • #40
No.
You are referring here to:
10 blocks times 1 cubic meter per block times 5095 kg per cubic meter = 50950 kg.
The number was acceptable, but the units were wrong.
That 50000 is not a weight. It is a mass. It is not in units of Newtons. It is in units of kilograms.
The weight of a mass is the mass times the acceleration of gravity. The acceleration of gravity on the surface of the Earth is approximately 9.8 meters per second per second.
50000 kg times 9.8 meters/second2 = a weight of 490,000 kg-meters/sec2 = 490,000 Newtons. Call it 500,000 Newtons.
100 meters divided by 3600 seconds = .028 meters per second velocity. That was correct.
Power = force times velocity.
500,000 Newtons times 0.028 meters per second = 14,000 Newton-meters/second = 14,000 Watts.
You double-dipped on height, multiplying by the 100 meters once to get your estimate of 0.28 meters per second fall rate and then again by that same factor of 100 for no reason.
You presented the result as 140 kilowatt-seconds. That is a unit of energy. Both the number and the units were incorrect.
You really need to keep track of units in your calculations.
  • #41
Thank you jbriggs and also for pointing out he errors in my calculation. I realize i keep mixing the units. maybe i need to rethink the whole thing.
Thank you to everyone for helping.
  • #42
I just wanted to comment that a unit like 'kW per hour' is not meaningless, although it is apparently being used incorrectly by jaxodius. As an example of what this unit (kW per hour) would mean, the world produces electric power at a certain rate - something like 2.2 TW in 2008 (or equivalently 2 billion kW. In the year 2000 this rate was more like 1.6 TW, so it has increased by 0.6 TW ( or 600,000,000 kW) in 8 years. 8 years is about 70,000 hours, so the rate of increase of electric power production is
600,000,000 kW / 70,000 hours, or
8600 kW/hr. This is roughly one new large electric power plant (generating 1 gigawatt, i.e. a million kW) every 4 or 5 days.
The situation is very similar to the unit meters/sec/sec (meters per second per second or meters per second squared) which is a unit of acceleration. If you drop a stone near the surface of the Earth it accelerates downward with an acceleration of 9.8 meters per second per second; when you first let go of it its speed is zero, but a second later it will be moving downward with a speed of 9.8 meters per second.
  • #43
I'll grant you that, tomfy, but it is pretty rare (and not applicable here). Good point though. And welcome to PF!
  • · Replies 74 ·
11K
  • · Replies 17 ·
  • · Replies 32 ·
