Calculating the value of resistors
  • Thread starter Thread starter beefertoo
    Resistors Value
Using a resistor to limit voltage for a motor is not advisable, as it can lead to stalling due to varying current demands based on the load. Instead, diodes are recommended for voltage reduction, as they provide a more stable voltage drop without limiting current. For instance, using eight diodes in series can effectively reduce 12V to 6V, accommodating a motor's varying load. It's crucial to experiment with the setup to achieve the desired motor speed, as the relationship between voltage and RPM is not straightforward. Understanding the specific motor characteristics and load conditions is essential for effective operation.
beefertoo
if my 12volt motor running with 12v draws 10amps, am i right in thinking if i put 6 volts on the same motor then it would run at half speed? how would i work out the value of the resistor needed?
i know i need to use ohm's law somehow but it's been a while since I've had anything to do with this and can't remember just how to do it...
thanks
I don't think the speed of an electrical motor is necessarily proportional to the voltage. It depends heavily on the characteristics of the load you are putting on the motor. I think you need to experiment to find the correct values.
Say that a 12V motor can barely lift a given weight, running at some non-zero RPM. On 6V it will then not be able to lift the weight, and the RPM will be zero. So the relasionship will be complicated, and I think it is even for an "unloaded" motor (i.e when the only load is the ball bearing friction and air resistance within the motor itself).
EDIT: This seems like a good source of info:
http://www.4p8.com/eric.brasseur/emamem.html
If you know the power needed to drive the load for each value of RPM, then you might be able to use those formulas to derive the approximate relationship between voltage and RPM for your motor. I didn't look thoroughly, though.
Torquil
Every motor is different. In general, if you don't trust manufacturer's specifications for rpm versus voltage or max torque or what have you, your best bet is just to create a quick empirical fit for your motor's speed as a function of voltage AT the load that you intend to use.
Resistors are not suitable because they are current limiting and a motor draws varying currents depending on the load.
Use diodes instead as they are voltage limiting not current.
The forward voltage drop on a diode is 0.75 volt so if you put eight diodes in series you drop from 12v to 6v.
The diodes used would have to be able to carry a bit more than your maximum load of 10 amps.
I have used this to run the windscreen wiper motor of an old car that I upgraded from 6v to 12v.
The load on the motor depended on how wet (or dry) the windscreen was. If I had used resistors the wipers would have stalled.
Experiment by adding or removing a diode to obtain the speed that you require.
Yes, alternatively use a Zener diode if you don't want a string of diodes. You can find them for different voltages.
Torquil
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
