Calculating time derivative of Magnetic force
The discussion focuses on calculating the time derivative of magnetic force for particle interactions, specifically seeking the jerk (the time derivative of acceleration) for an n-body simulation. The magnetic force is expressed in terms of particle velocities and their relative positions, with the need to apply the chain rule for differentiation. The challenge arises in differentiating the distance between particles and the unit vector pointing from one particle to another, which involves understanding how to handle the norm of a vector during differentiation. Participants provide guidance on using position vectors and their derivatives to derive the necessary equations. The conversation concludes with the poster expressing gratitude for the clarification and a commitment to work through the calculations.
Sagekilla
Hi all, I ran into a bit of an issue trying to figure out how to properly differentiate the magnetic force due to particle interactions. To be specific, I'm actually looking for the time derivative of acceleration (jerk) due to the magnetic force, but it's essentially the same problem.
For the record, this is not homework at all. It's something I require for a n-body simulation I'm doing, and I need to calculate jerk to do higher order integrations.
I know that the magnetic force is, in expanded form:
\vec{F} = \frac{\mu_{0} q_{1} q_{2}}{4\pi r^{2}} \vec{v_{1}} \times (\vec{v_{2}} \times \hat{r}) = \frac{\mu_{0} q_{1} q_{2}}{4\pi r^{2}}((\vec{v_{1}} \cdot \hat{r}) \vec{v_{2}} - (\vec{v_{1}} \cdot \vec{v_{2}}) \hat{r})
Where r-hat is the unit vector pointing from particle 2 to particle 1, and r is the distance between the two particles.
I don't even know where to begin to do this. I understand I need the chain rule but when I tried doing the same for a simpler vector (gravitational acceleration), the actual result ended up having a bunch of dot products in there that I had no idea how to get.
Can anyone guide me in the right way?
When you do the chain rule you will get, in addition to the derivative of velocity, derivatives of r and r_hat. I suppose you are asking what those will be. You start by writing them out as the particle position vector:
\vec{r} = \vec{r_1} - \vec{r_2}
\hat{r} = \frac{\vec{r_1} - \vec{r_2}}{|\vec{r_1} - \vec{r_2}|}
when you take the time derivative of these you get derivatives of the position vectors, which is also the velocity of the particle.
Well, if I start with something simple like the position unit vector:
\frac{d}{dt}\hat{r} = \frac{d}{dt}\frac{\vec{r_{1}} - \vec{r_{2}}} {| \vec{r_{1}} - \vec{r_{2}} |}
\frac{d}{dt}\hat{r} = \frac{|\vec{r_{1}} - \vec{r_{2}}| (\vec{v_{1}} - \vec{v_{2}}) - |\vec{r_{1}} - \vec{r_{2}}|'(\vec{r_{1}} - \vec{r_{2}}) } {|\vec{r_{1}} - \vec{r_{2}}|^{2}}
My problem here is: How do I differentiate the |r1 - r2| properly?
sorry, i will try to derive it here
if
r^2 = \vec{r}\cdot\vec{r}
then
\frac{dr^2}{dt} = \frac{d\vec{r}}{dt}\cdot\vec{r} + \vec{r}\cdot\frac{d\vec{r}}{dt} = 2\frac{d\vec{r}}{dt}\cdot\vec{r}
r = \sqrt{r^2}
so,
\frac{dr}{dt} = \frac{1}{2\sqrt{r^2}}\frac{dr^2}{dt} = \frac{1}{r}\frac{d\vec{r}}{dt}\cdot\vec{r} = \frac{d\vec{r}}{dt}\cdot\hat{r}
where
\hat{r} = \frac{\vec{r}}{r}
\frac{d\hat{r}}{dt} = \frac{d\vec{r}}{dt}\frac{1}{r} - \frac{\vec{r}}{r^2}\frac{dr}{dt}
finally
\frac{d\hat{r}}{dt} = \frac{1}{r}(\frac{d\vec{r}}{dt} - (\frac{d\vec{r}}{dt}\cdot\hat{r})\hat{r})
and substitute in the vector r_1 - r_2 for r.
Ah, thank you. My biggest issue with differentiating the above equations was trying to figure out how the the norm of a vector would differentiate with respect to a variable.
I'll work these out and post my results.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
