Calculating time in which flux changes
  • Thread starter Thread starter jitznerd
    Flux Time
The discussion revolves around calculating the time over which magnetic flux changes in a coil with 50 turns, transitioning from 10 mWb to 20 mWb, resulting in an induced emf of 62.5V. The formula used is derived from Faraday's law, where time is calculated as t = (Number of turns x Change in flux) / emf. The initial calculation yielded 8 seconds, but there was confusion regarding the units, particularly the change in flux being in milliWebers rather than Webers. Clarification was sought on the correct application of units, emphasizing the importance of using the correct values for accurate results. Ultimately, the discussion highlights the necessity of careful unit management in electromagnetic calculations.
jitznerd
1. Homework Statement [/b]
If the magnetic flux linking all the turns of a 50 turn coil changes from 10mWb to 20mWb and induces an emf of 62.5V in the coil, calculate the time over which the flux changes.
e=Nd x change in flux / dt
Not sure if this is correct formula but transposed formula to:
t = Number of turns x Change in flux / e
= 50 x 10 / 62.5
t = 8s
= 50 x 10 / 62.5
t = 8s
Could you do it one more time, this time showing the units? Your answer may be correct (seems kind of long), but it would be much clearer if you showed units (and included exponents with numbers like milliWebers...)
Yeah I thought 8 seconds seemed a long time, that's what made me query if I had gone about it right.
The question is typed exactly as I have been given with those units, then I have used what I think is Faradays law:
E (volts) = N (number of turns) x change in flux (Webers) / Time (s)
Then transposed this to:
Time = N (number of turns) x change in flux (Webers)/ E (volts)
This gave me the 50 x 10 / 62.5 = 8 seconds.
I initially went used:
Change in time = change in flux (Webers) / E (volts)
= 10/62.5 = 0.16 secs (this answer seemed a little more realistic although it hadnt brought the 50 turns into the equation.
try a change in flux of 10 mWb (0.01 Wb)
= 50 x 10 / 62.5
t = 8s
The change in flux is not 10 Wb. It's 10 mWb.
  • · Replies 16 ·
