Calculating torque to turn/twist a trailer on wheels when it's not moving
  • Thread starter Thread starter Calvin Horst
    new member
The discussion centers on constructing a mobile building for pastured chickens, measuring 24' by 44' and weighing approximately 16,000 pounds when loaded. The builder is considering using smooth balloon tires for easier movement and plans to pull the structure with a winch. Key considerations include the structural integrity of the chassis, the alignment of wheels during movement, and the building's ability to withstand wind. Participants emphasize the importance of design and cross-bracing for stability, as well as the need for a visual sketch of the proposed structure. Overall, the focus is on ensuring the building can be effectively maneuvered in various field conditions.
Calvin Horst
How did you find PF?: web search.
I am new to all this. There was another post similar to this, but it was above my current education. I didn't go beyond 8th grade. So, beyond that I learn by doing, and through other friends.
I'm constructing a building on wheels for pastured chickens. 24' wide, 44' Long and weight roughly 16,000 pounds when loaded. Building is capable of moving sideways and end ways.
Wheels are 31" diameter 15" wide with bar tread 4.5" O.C. 1.5" wide bar standing 0.625" high. And 3" in-between the bars. 4 wheels = 4,000 lbs. per wheel.
I am considering putting smooth Balloon tires on which would turn much easier. And pulling the building with a winch.
Another factor is how muddy the field is.
Welcome to PF. :smile:
Dat's a lot of chickens! Do you have any pictures of similar structures/trailers?
AKA Chicken tractor. https://en.wikipedia.org/wiki/Chicken_tractor
https://mobilechickenhouse.com/commercial-chicken-tractor/
How many wheels? To move the structure, you will need to pull on all the wheel modules at the same time. The direction of the pull will need to align the individual wheels.
The problem will be the strength of the framework or chassis. That will come down to the structural design, and how wires are used for cross-bracing.
Wind design will be important. What are the strongest winds it must withstand? What will the walls and roof be made from?
We need a sketch of your basic ideas.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
