Calculating total resistance of a combination circuit with a diagonal resistor?
The discussion centers on calculating the total resistance of a combination circuit featuring series and parallel resistors, including a diagonal resistor. The user correctly applied the series and parallel formulas, specifically using the formula (R1*R2)/(R1+R2) for the parallel resistors. The final calculated total resistance was 8.72 ohms, which was confirmed as accurate by another participant. Additionally, various circuit simulation tools for Linux and Windows, such as gspiceui and LTSpice, were recommended for modeling circuits and analyzing voltage drops and currents.
  • Understanding of series and parallel resistor configurations
  • Familiarity with the formula for total resistance in parallel circuits: (R1*R2)/(R1+R2)
  • Basic knowledge of circuit analysis techniques
  • Experience with circuit simulation software like LTSpice or gEDA
  • Research how to use LTSpice for circuit simulation and analysis
  • Explore the functionalities of gEDA for circuit modeling on Linux
  • Learn about advanced circuit analysis techniques, including mesh and nodal analysis
  • Investigate the impact of resistor tolerances on total resistance calculations
Electronics students, electrical engineers, hobbyists working on circuit design, and anyone interested in understanding and calculating total resistance in combination circuits.
WetFork
I have been given this problem, I've simplified it down to a total resistance however I'm unsure on whether I have done it correctly. Any pointers would be nice, thanks.
First of all I added the two resistors together in the top right as they are series. I then used that product with the (R1*R2)/(R1+R2) with the diagonal resistor as they are in parallel. I then added that up with the one in the bottom right as they are now in series. Used that product with the parallel formula with the one in the middle and then added the last two on the left.
My answer I got was 8.72 ohms total resistance, have I correctly done this?
Thanks for any help provided
That sounds good to me.
If you have Linux you might be interested in the following packages:
gspiceui
gnucap
gEDA
gwave
They can help you model circuits and read voltage drops and currents and see how a circuit will respond to certain inputs etc etc. They're the Linux attempt to create something like "SPICE"
Windows has "LTSpice" which is useful as well.
They're all free to use.
  • · Replies 19 ·
  • · Replies 60 ·
10K
