Calculating velocity with force
  • Thread starter Thread starter mia_material_x1
    Force Velocity
The discussion centers on calculating the horizontal velocity of a 2kg object subjected to a net force defined by F=A+Bt^3, where A=5N and B=2N/s^3. The correct approach involves integrating the varying acceleration, derived from the force equation, rather than assuming constant acceleration. The integration yields the velocity formula v(t)=2.5t + (1/4)t^4, which provides a more accurate result. In contrast, using the constant acceleration formula led to an incorrect velocity calculation. The importance of recognizing when acceleration is not constant is emphasized in the solution.
mia_material_x1
A net horizontal force F=A+Bt^3 acts on a 2kg object, where A=5N and B =2N/s^3. What is the horizontal velocity of this object 4 seconds after it starts from rest?
F=ma
F=ma=5N+(2N/s^3)t^3
(2kg)a=5N+(2N/s^3)(4s)^3 ==> a= 2.5N + t^3 = 66.5m/s^2
a=dv/dt ==> v=(2.5 N)t + (1/4 N)t^4
when t= 4s
V= (2.5)(4) +(1/4)(4)^4 = 74m/s
I used V=Vi+at when Vi=0m/s, t=4s, a=66.5m/s^2, and I got V=266m/s
Which one is correct way of solving it, and why? Please let me know. Thanks
It seems like the first method is right.
V = Vi + at only applies when acceleration is constant .
Likes mia_material_x1
I mean, ## v(t) = v(0) + \int_0^t a(\tau) d\tau ##, which as you correctly pointed out is
## v(t) =0+ \int_0^t \frac{ F(\tau)}{m} d\tau \\
\quad = \int_0^t 2.5 + \tau^3 d\tau \\
\quad = \left. (2.5\tau + \frac14 \tau^4) \right|_0^t \\
\quad =2.5t + \frac{t^4} {4} ##
Since acceleration is increasing (quickly) with time, it should be pretty clear why if you use a(4) as your constant acceleration in the equation:
v(t)=v_i+at,
the result would be so much larger than you found with the correct method.
Yeah you are right. I just assumed the acceleration was constant that's why the result was incorrect. Thanks guys!
