Calculating Work Done for Carrying Tool Boxes
6 replies · 2K views · last reply
cyberjupiter
A carpenter is holding two tool boxes of mass 19kg and 21kg respectively. Calculate the work done to carry the tool boxes through a horizontal distance of 16m.
W = mgh
m = 21kg + 19kg
g = 9.81ms^-2
h = 0
W = (21 + 19)(9.81)(0)
W = 0J
Is this correct? And if this is correct, would you explain why it is 0J?
The formula for work involves the dot product of two vectors.
W = F . s
Does this give you a hint?
(Yes, your answer of 0J is correct.)
In order to do work, you must move an object with mass in the direction of a force vector.
So if I use W = F . s, then it would be
W = (19 + 21)(9.81)(16) ?
Or is it,
W = (19 + 21)(9.81)(16) cos 90 ?
Or is it,
this ^^^
Instead of writing the vector formula, it is often expressed as W = F s cosθ
and that's probably the best one to memorise.
NascentOxygen, would you tell me why the angle is 90? Shouldnt it be 0? And how about if I use sin 0? I will still get 0J.
The question just tests how easily confused you are.
The only force mentioned is weight, and it acts downwards ⇓
while the motion described is horizontal ⇒
and the angle between those two vector quantities is ... ?
You want to invent your own formula using sin 0° ? What angle in this picture is 0°?
