Calculating Work for a Bead on a Square Loop in an Electric Field
8 replies · 2K views
scorpius1782
A small bead is on square loop in the xz plane with dimensions (±R, 0, ±R). An electric field is turned that is ##\vec{E}(\vec{r})=-Cx\hat{z}##
Calculate W
##W= \int q\vec{E}\bullet dl##
Starting with z direction:
[tex]q\int_{-R}^R -Cx\hat{z} (dx\hat{x} + dy\hat{y}+ dz\hat{z})[/tex]
=##-Cq \frac {x^2}{2} |_{-R}^R=-CqR^2##
I believe that the total work would just be 2 times this quantity because since the E field isn't in the correct direction in order to move the charge in the x direction. But this doesn't make sense to me within the problem context. Am I missing something?
hi scorpius1782! :smile:
(type \cdot not \bullet :wink:)
sorry, but that makes no sense :redface:
you need to write a dot product
try again (and use a specific arm of the loop) :smile:
thank you for the \cdot! I couldn't remember what it was (kept thinking \vdot) so I gave up and used bullet.
the vertical (z) part of the box from -R to R at x=-R
##\int_{-R}^R-Cqx\hat{z}\cdot dz \hat{z}##
I didn't think of it before but since here x=-R I can put that in for x in this integral. I believe that since there is no change in x or y then dx and dy are zero.
This means that ##CqR\int_{-R}^R\hat{z}\hat{z}dz=CqR(R+R)=2CqR^2##
Then for x=R: ##\int_{R}^{-R}-CqR\hat{z}\cdot dz \hat{z}##
##=-CqR\int_{R}^{-R}\hat{z}\hat{z}dz=-CqR(-R-R)=-2CqR^2##
Is this better?
scorpius1782 said:
… x=-R …
yes :smile:
erm :rolleyes:
Hmm, seems I didn't distribute my negative sign there!
I am, thank you. I assume since you made no comment that my understanding of the horizontal forcei is correct? That is where z=±R there is no work?
yes, for displacement of constant z, the component of the field along the wire is zero, so the work done is zero :smile:
