Calculating Work Potential and Power Conversion of a 50kg Box
The discussion revolves around calculating the potential energy of a 50 kg box positioned 2 meters high and exploring the relationship between joules and watts in the context of energy conversion and power. Participants are examining the implications of these calculations and the definitions of energy and power.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of potential energy and question the conversion of joules to watts, particularly in terms of efficiency and time. There are inquiries about how energy is expended over time and the implications of slowing down the fall of the box. Some participants explore the relationship between energy, work, and power in various scenarios, including the use of a lightbulb.
The conversation is active, with participants providing clarifications on the definitions of joules and watts, and discussing the implications of time on power calculations. There is an ongoing exploration of how energy is converted and the effects of different scenarios on power output, but no consensus has been reached on all points raised.
Participants are navigating through foundational concepts in physics, including gravitational potential energy, the distinction between energy and power, and the effects of time on these quantities. There are also references to specific conditions, such as the height of the box and the gravitational constant, which influence the calculations discussed.
sonofahb
ok let's say i have a box that's 50kg. its 2 meters high. so i plug and chug those into the equation and i get 980 joules. 50*9.8*2=980. ok sooo this box has 980 joules potenetial work.
the question i have is since 1 joule equals a watt would it be safe to say that what we have is almost a kilowatt.(considering if you could convert with 100% efficiency which i know you cant) but would it convert like that or is there something I am missing? also the total work that could be done is an amount of energy. and watts are usually defined as a rate soooo how would that convert. thanks in advance.
That rightt there is incorrect. Joule is the unit of energy, Watt is power.
[itex]1W=1Js^{-1}[/itex] is the correct conversion.
so a joule per second equals 1 watt. hmmmmm... so how much electrical potential would there be from 980 joules? i guess I am tryng to find out an amount of electrical potential from that box falling. could you or anyone pls help? this whole joule per second throws me off as to what it really means. i know it takes 1 joule to heat 1 gram of water 1 degree c but how does the whole "per second" come into play? thx
EDIT:would it be something like if the box fell in one second completely to the floor then there would be 980 watts?
Yes. A watt is work over time. Watt= Kgm^2/s^3. All of the gravitational energy will be converted to kinetic while its falling, and since power it totall energy over time, it would be 980J/1s giving you 980W or about 1.31 horsepower.
oh i see. 1 joule = 1 watt second. so 980 joules would equal 980 watt seconds. which would equal 16 watts per minute for 163 minutes? is this right?
EDIT:so i would get 1.31 horsepower for 1 second?
not quite. watts per time is an entirely different unit. don't confuse joules/time with watts/time. and yes assuming your Eg=980J and the box takes 1 second to fall, the power would be about 1.3 horsepower. allthough a box of that height would take less than a second to fall. in order to take a full second to fall it must be 4.9m above ground. assuming of course you are on Earth with gravity at 9.8m/s^2. and if the height is raised, yet the energy is still 980, then the mass must be lowered.
If you used up all that potential energy in one second, then you would have 980watts. But it would only last one second, because you've wasted (or more accurately, converted) all of the potential into something else.
Watts is a rate per time, a joule is independent of time. Just think of distance and velocity. If I traveled 25m, are you saying my velocity is 25m/s? Well, it doesn't neccessarily have to be.
a joule is not independent of time. the very deffenition of a joule has time in it. (Kgm^2/s^2) with s=seconds. watt really isn't rate per time. watt itself is a rate of how fast energy can be used, or as you said more accurately, converted.
wow thanks for the replies fellas. let's say i could slow the box down as it was falling. say have it fall the 2 meters in say 1 minute. would the output still be the same? i mean if i had it tied to a rope, there would be tension on the rope for 1 minute. isn't there more "energy" here? if I myself was to hold the 50 kg for 1 minute i would burn more energy than if i let it fall naturally in my hands. i guess what I am asking is if time is also i factor here. thanks guys
if it has 980 joules and it expends that in 120 seconds then your talking about 8.16watts on average. [i say average because it will fall more slowly at first and more quickly later,assuming freefall the power would depend of the speed its falling].
as far as energy is concerned. your elevated box has 980 joules of potential energy. full stop. [period in usa].
Tension is a force. VERY different from energy.
the energy you would burn up holding the 50kg weight by a rope does not contribute to the potential energy of the box. its really just chemical energy in you cells being burned away, to, i guess, eventually produce heat. yes you are using your own energy and producing power, but not mechanical work!
AS FOR TIME BEING A FACTOR. yes time is what defines POWER, power is the RATE at which you do work. if you use 1 joule of energy in 1 second then your producing 1 watt of power.
There isn't anymore energy there because the formula for gravitational potential energy is Eg=mg(delta)y. the rate would only effect the power of an object. slowing it down means its less efficent so it would be a lower number of watts. it would instead be 980J/60s. which is 16.33 watts, or 16.33J/s. the energy from the box is still being converted from potential to kinetic just like before even if you slow it down. so the tension would not effect that. phlegmy brings up a good point, to remember force and work are different things. FORCE is mass X acceleration. ENERGY or work can be defined as Ek=force X displacement.
ok i think I am catching on here but... let's say we have a 100 watt lightbulb that's on for 1 hour. how many watts did the lightbulb use per second? would it be 100/3600? or .03 watts? considering 100 watt times 10 hours would be 1 kw. would it work out the same way?
EDIT: pls just bare with me i know these are elementary questions I am just trying get a grasp on the whole quantity of electricity and the equivalents ect ect.
also if .03 watt is correct then a lightbulb uses less than a joule per second?
sonofahb said:
... let's say we have a 100 watt lightbulb that's on for 1 hour. how many watts did the lightbulb use per second?QUOTE]
your nearly there, except:
the light bulb uses 100w CONTINUALLY while it is on
thats 100 joules every second
the light is on for 1hr =3600 seconds
that means it uses 100j/s * 3600 seconds = 360,000 joules
joules is the unit for energy its how much energy you have used, as time goes on it gets bigger as you keep using energy
watts is unit for power, its how quickly your using the energy, if you keep using energy at the same rate your "watts" doesn't change,
IF you switch on the light bulb would be using 100 watts. if you left it on for a year and came back, it would still be using 100 watts.
i think where you are getting confused here is the difference in watts and joules. its better to think of watts as a rate rather than a unit. it is a unit but it is a unit of rate. the number of watts is how many joules per second an object uses. this is how much work can something get done over time. a light bulb watt rating is to show you how much energy is used every second it is on. the light will consistantly use that much energy. if it is a 100w light bulb, it will consistantly use 100joules/second. just remember to think of watts as a rate of work.
wow good posts. so if a machine uses 10000 watts then it is really using 10000 joules per second. which means that in an hour (10000*3600=36,000,000 joules) which would be the equivalent of 10 kw. is this right? how many kilowatt hours would that be?
Gravitational potential is independent of time, as it is conservative. While you make a point that any joule has time dependence from the acceleration from the force in general, this does not hold for gravity which we assume is constant. Power is a rate of change over time. Its a time derivative. How can it not be a rate per time?
Look to the physics and not just dimensional analysis.
good point. i should have worded that differently. i was just trying to clear up the difference between a watt and a joule. thank you for the correction.
