Calculating Work: Pushing a Block Up a Frictionless Incline
  • Thread starter Thread starter featherua08
    Work
The discussion focuses on calculating the work required to push a 25-kg block up a 2-meter frictionless incline at a 30-degree angle. The relevant formula for work is W = F * (delta X), where F is the force component acting along the incline. The correct approach involves determining the gravitational force component acting parallel to the incline, which is calculated using W = (F cos θ)(delta X). The participant initially calculated the normal force but did not account for the incline angle, leading to confusion.
  • Understanding of basic physics concepts such as force, work, and gravity.
  • Familiarity with trigonometric functions, particularly sine and cosine.
  • Knowledge of Newton's second law (F = ma).
  • Ability to apply coordinate systems to physical problems.
  • Study the concept of gravitational force components on inclined planes.
  • Learn how to apply trigonometric functions in physics problems, specifically sine and cosine for angles.
  • Explore the relationship between work, force, and distance in various contexts.
  • Practice solving similar problems involving frictionless surfaces and inclined planes.
Students studying physics, particularly those focusing on mechanics and inclined plane problems, as well as educators looking for examples of work calculations in real-world scenarios.
featherua08
How much work is required to push a 25-kg block up 2m up a frictionless 30 degree incline at a constant speed?
W=F(delta X) ; W=(F cos theta)(delta X)
I did n=mg -- n=(25)(9.8)=245 & that is the correct answer..but I don't understand how.
Well, by coincidence you didn't factor in the angle and still go the right answer.
Start off by having a coordinate plane that is parallel to the incline of the ramp. Figure out what component of the total weight (mg) you are pushing up the ramp and by what distance.
I don't think I understand what you mean. The distance is 2m and wouldn't the total weight simply be the weight of the block?
