Calculation of Kinetic Energy in Rotation Motion
The discussion centers on the calculation of kinetic energy in rotational motion, specifically for a rigid body shaped like an 'H' rotating about a fixed axis. The user initially struggles with applying the kinetic energy formula KE = (1/2)MVCM² + (1/2)ICMω², questioning the neglect of the translational kinetic energy term. Clarification is provided that when considering rotation about an axis not through the center of mass, the kinetic energy of the center of mass is already included in the moment of inertia. The conversation also touches on the parallel axis theorem and the importance of using the correct moment of inertia for calculations. Ultimately, the user resolves their confusion and arrives at the correct answer after correcting their approach.
Amartya Sen
Respected Physics Gurus/experts...!
I am confused in the application of Kinetic energy Expression, i.e, KE = (1/2)MVCM2+(1/2)ICMω2
I had been trying out this question actually(it's pretty simple though:-p)...---
"A rigid body is made of three identical thin rods each of length L fastened together in the form of letter H. The body is free to rotate about a fixed horizontal axis AB that passes through one of the legs of the 'H'. The body allowed to fall from rest in a position in which the plane of H is horizontal. What is the angular speed of the body, when the plane of H is vertical?
https://physicsforums-bernhardtmediall.netdna-ssl.com/data/attachments/80/80350-15ec1ccefce05dd0a160c18183367070.jpg
KE = (1/2)MVCM2+(1/2)ICMω2[/B]
& Work Energy Theorem
I tried by considering the whole H at it's centre of mass and the applied the formulae but the answer I got was incorrect. My friend told me that since the 'H' is only rotating, the (1/2)MVCM2 term could be neglected...Why is it so? The CM has some velocity afterwards... Although the correct answer can be obtained by following this approach
Any help would be appreciated..!
You can treat the body as purely rotating, but if you do, make sure you use the rotational inertia about the axis of rotation, not the center of mass.
I know that...But why it is so..? And what's wrong with the application of the original formula?
Hello Amartya, :welcome:
If you look carefully at the definition of moment of inertia -- in this case about an axis not through the center of mass -- you can see that the kinetic energy of the center of mass is already accounted for. To check you can work it out for a simple point mass instead of for an extended object.
There is a theorem - the parallel axis theorem, which google -- that links the moment of inertia around an axis through the center of mass to the moment of inertia around a parallel axis NOT through the center of mass
Thanks BvU for your help..! :smile::smile::smile:
In the first place, I do know the parallel+perpendicular axis theorems. :wink:
But the formula says that we have to use the MoI about the COM of the object, not about the axis about which it is rotating.
Saying this, I want to also add that it's unclear that if we do have to use MOI about COM, so which plane we have to use?? ( As in this case---I think its the axis about which the direction of original rotation remains changed)
Next, I have used the formula exactly as it is in other questions regarding which there are no complaints...
Man, I do feel sometimes dizzy regarding some concepts in rotational motion..(toughest chapter for me)
It makes me go :doh::doh::doh:...
Plz, lead me out of trouble..
No problem. Show your calculations and someone will point out where things go awry -- if at all (sometimes book answers can be wrong too). In your case, friend is wrong (or misquoted...).
Here's my solution anyway...
Considering the body to be centred at the mid point of the middle leg of the 'H', we have,
mgl/2 =mv2/2 + [(ml2/12 + ml2/4 + ml2/4)ω2]/2
which on simplifying and putting v=ωl/2 gives:
ω=(12g/17l)^0.5
Totally wrong.
But you don't have to use that formula. (But you can if you wish.)
Does "m" stand for the total mass? Your expression for MOI is not clear.
Problem statement says three identical rods of length L. From your ##I_{\rm c.o.m.}## I gather each rod has mass m. In that case there should be a 3 mgL/2 = 3 mv2/2 + ... on the left ! :smile:
And you can quickly check this parallel axis theorem as well.
Oh Yeah..Yeah...I'm sorry. It should be as BvU said. Thanks BvU..
Anyway, even after the correction, answer comes to be wrong...
How can you tell that the answer is wrong ?
Yahoo...Finally I arrived the answer...It turns out that I had been replacing v2 by ω2l2 instead of ω2l2/4 in the final step ...?:)?:)?:)
Thanks pals... And sorry for wasting your precious time..if I did.
