Calculation of solubility in water
The discussion centers on the solubility of helium gas in a 3000-liter water tank pressurized with 1 bar of helium. It questions whether the solubility law can be applied to the entire volume of water, suggesting a calculation of total solubility as 0.00145 g/litre multiplied by 3000. The conversation also explores whether solubility is influenced by the surface area of water exposure or the resistance to mass transfer within the liquid. Additionally, it raises concerns about estimating the degasification rate of helium when subjected to varying nitrogen gas pressures or vacuum conditions, noting that this process is complex and requires further exploration. The discussion highlights the challenges in accurately calculating gas transfer from water to the gas phase.
vinchem14
Dear Forum members,
Situation: 3000 litre of water is pressurized with 1 bar helium gas in closed tank.
question 1: My question is that, if i know the solubility of helium gas in water at 1 bar partial pressure of helium over water at temp of 25 deg is 0.00145 g/litre, Whether i can apply this solubility law to entire bulk volume of water.
Solubility value for 3000 litre of water = 0.00145*3000 = ?
Whether solubility of helium gas depends upon the surface area of exposure of water or resistance offered by the liquid to transfer the solute from water interface to its bulk volume. or either i should interphase mass transfer theories to calculate the exact amount of soluble gases in 3000 litre of water.
question 2: If we have estimated the solubility in 3000 litres of water, how can we similarly estimate the degasification rate of solublized helium from water, if same water is kept under different conditions of nitrogen gas pressure or in a vacuum condition (after achieving sufficient solubility with helium gas). Is there any law to calculate the amount of solublized gas transfer from water to gas phase.
You can assume concentration of helium in the bulk is the one given if the system is left to equilibrate for long enough. With mixing 'long enough' means hours rather then days.
Speed of degasification is a completely different problem, one that is much more difficult to handle. Hopefully someone else will be able to help.
Hello! I've been brainstorming on how to prevent a lot of ferrofluid droplets that are in the same container. This is for an art idea that I have (I absolutely love it when science and art come together) where I want it to look like a murmuration of starlings. Here's a link of what they look like: How could I make this happen? The only way I can think of to achieve the desired effect is to have varying droplet sizes of ferrofluid suspended in a clear viscous liquid. Im hoping for the...
Hello everyone! I am curious to learn how laboratories handle in-house chip manufacturing using soft lithography for microfluidics research. In the lab where I worked, only the mask for lithography was made by an external company, whereas the mold and chip fabrication were carried out by us. The process of making PDMS chips required around 30 min–1 h of manual work between prepolymer casting, punching/cutting, and plasma bonding. However, the total time required to make them was around 4...
