MHB Calc Challenge IV: Evaluate Limit of Int.
The discussion focuses on evaluating the limit of the integral $$\lim_{{k}\to{\infty}} \int_{k}^{2k} \frac{k^3x}{x^5+1}\,dx$$. MarkFL efficiently solves the challenge using L'Hôpital's rule, prompting praise from other participants. There is a playful suggestion to solve the problem again without relying on L'Hôpital's rule, which leads to lighthearted banter. Participants express interest in exploring alternative methods for the solution. The conversation highlights both the mathematical challenge and the camaraderie among forum members.
anemone
MHB
POTW Director
Evaluate $$\lim_{{k}\to{\infty}} \int_{k}^{2k} \frac{k^3x}{x^5+1}\,dx$$.
Mathematics news on Phys.org
My solution:
I would write the limit as:
$$L=\lim_{k\to\infty}\left[\frac{\int_{k}^{2k}\dfrac{x}{x^5+1}}{k^{-3}}\right]$$
Observing that we have the indeterminate form 0/0, application of L'Hôpital's rule yields:
$$L=\lim_{k\to\infty}\left[\frac{\dfrac{k}{k^5+1}-\dfrac{4k}{32k^2+1}}{3k^{-4}}\right]$$
This can be simplified to:
$$L=\frac{1}{3}\lim_{k\to\infty}\left[\frac{k^5\left(28k^5-3\right)}{\left(32k^5+1\right)\left(k^5+1\right)}\right]=\frac{1}{3}\cdot\frac{28}{32}=\frac{7}{24}$$
MarkFL said:
My solution:
Aww...that is fast and efficient of you, MarkFL to solve my today challenge! Well done MarkFL!
When you solved it using the L'Hôpital's rule, your solution becomes very neat and straightforward. I am wondering if you want to tackle it for another time without using the help from the L'Hôpital's rule, hehehe...
Why do you want to tie my hands like that? (Wasntme)
Because I would sing a song for you if you try that!:p
Solution without the use of L'Hôpital's rule:
Since $x^5+1<x(x+1)^4$ and $x^5<x^5+1$ for $x\ge 1$, we have
$\dfrac{1}{(x+1)^4}<\dfrac{x}{x^5+1}<\dfrac{1}{x^4}$ for $x\ge 1$
It then follows that
$\displaystyle k^3\int_{k}^{2k} \frac{1}{(x+1)^4}\,dx<k^3\int_{k}^{2k} \frac{x}{x^5+1}\,dx<k^3\int_{k}^{2k} \frac{1}{x^4}\,dx$ for every $k\ge 1$.
Now,
$\displaystyle \begin{align*} k^3\int_{k}^{2k} \frac{1}{(x+1)^4}\,dx&=\dfrac{k^3}{3}\left(\dfrac{1}{(k+1)^3}-\dfrac{1}{(2k+1)^3}\right)\\&=\dfrac{1}{3}\left(\left(\dfrac{k}{(k+1)}\right)^3-\left(\dfrac{k}{(2k+1)^3}\right)^3\right)\\&=\dfrac{1}{3}\left(1-\dfrac{1}{8}\right)\text{when $k$ approaches $\infty$}\\&=\dfrac{7}{24}\end{align*}$
and
$\displaystyle \begin{align*} k^3\int_{k}^{2k} \frac{1}{x^4}\,dx&=\dfrac{k^3}{3}\left(\dfrac{1}{k^3}-\dfrac{1}{(2k)^3}\right)\\&=\dfrac{1}{3}\left(1-\dfrac{1}{8}\right)\text{when $k$ approaches $\infty$}\\&=\dfrac{7}{24}\end{align*}$
It follows by the Squeeze principle that hence $$\lim_{{k}\to{\infty}} \int_{k}^{2k} \frac{k^3x}{x^5+1}\,dx=\dfrac{7}{24}$$.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
