Calculus III - Multivariate limit problem
Jonmundsson
Show that for all points (\bf{a,b}) from \mathbb{R}^n \times \mathbb{R}^n<br /> this applies:
\displaystyle \lim _{(\bf{x,y}) \to ({\bf a,b})} \bf{||x-y|| = ||a - b||}
Not sure.
I thought about defining a and b as centers of two open balls with x in the a ball and y in the b ball but honestly I'm stuck so any tips to help me get started would be appreciated.
Thanks.
edit: for clarification ||x-y|| means the distance between x and y.
I'm not sure it may help, but I would deal with it by simply applying the definition of distance, that should be the norm of those vectors. So I would define X and Y as vectors of n components and show clearly, maybe with a few passages how they go to a and b.
Does ||x-y|| represent the Euclidean norm, i.e. ||x-y|| = \sqrt{(x_1 - y_1)^2 + (x_2 - y_2)^2} where x = (x_1, x_2), y = (y_1, y_2)?
If so, the norm is clearly continuous. Give a quick proof of it then your proposition follows.
If it's not the Euclidean norm, you can still prove that a norm on any vector space is continuous, from which your proposition will again follow.
D'oh. It's Euclidean.
Thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
