help needed with Euler's Equations
Thanks, Pervect, for the Goldstein reference. I checked it out of our library but, sad to say, I'm afraid that, acting on my own, I'd have to read and comprehend everything prior to the discussion of Euler's Equations, as well as brush up on my matrix algebra and calculus, to be able to understand and apply them correctly.
To try to bypass that time-consuming unpleasantness for the time being (it seems that this problem should have a relatively simple solution), let me pose a few questions about the torque-free equations, and their relation to my specific problem of a baton going from perfect twirling mode (90 deg precession angle) to perfect spinning mode (0 deg precession angle).
First of all, what puzzles me a bit is that in both extremes, the angular momentum is defined completely by the z-axis (no movement occurs in the z direction for something spinning perfectly about the z-axis), but for the in-between modes (where there is real precession), the spinning motion (though not the precession) does produce movement of the body's mass in the z direction (equal amounts + and -). Does this come from the series of frictionless taps to the opposite sides of the body's ends that I'm imagining to cause the change in its motion? If so, how does it disappear at the end of the exercise (when we go from one extreme to the next, and where, I assume, all the angular momentum comes from one or the other of spinning vs. twirling)? Is this related to the phenomenon of holding a gyroscope while sitting on a chair that can spin freely, turning the gyroscope through 90 degrees a certain way, and causing the chair to spin?
Secondly, and more importantly, the first of the equations with the right-hand side set to zero (see the wikipedia page on Euler's Equations) contains the terms I(sub-1) Omega dot(sub-1), the latter of which if my memory serves me correctly, is a rotational acceleration (time rate of change of angular velocity). Is this correct? And since, for this particular object under no torque, the angular speeds are unchanging, does this change in velocity simply specify the rate of precession (the time rate of change of the positioning of the baton's main axis)? If so, what the heck are omega-2 and omega-3 referring to? Movements in the x and y axes for a spinning top whose principal axis is not set to z?
Frankly, I'm at a loss as to how even to set the problem up. For example, I don't know whether I'm free to set omega-1 as the spin axis and omega-2 as the (same) twirling axis, or whether I should just work with the angular momentum equation, L=w(1)I(1) + w(2)I(2) + w(3)I(3). (I was trying to do the latter, when the above-mentioned "in-between mode" motion along the z-axis confused me.)
Also, I've seen elsewhere that a top's rate of spin and precession are inversely proportional, but that would necessitate dividing by zero in the extreme cases I'm interested in, which seems wrong. So, I was guessing (intuiting) that the spin and precession rates would vary inversely sinusoidally between zero and 90 degrees.
Sorry for blathering on this way.
Any help would be greatly appreciated. (This isn't for any coursework, BTW.)
