Can a rod survive dipping into a supermassive black hole's event horizon?
  • Context: High School
  • Thread starter Thread starter black hole 123
    Black hole Hole Rod
The discussion revolves around the effects experienced by a rod dipped into the event horizon of a supermassive black hole, focusing on the implications of tidal forces, acceleration, and the nature of orbits near the black hole. Participants explore theoretical scenarios, the physical behavior of materials under extreme conditions, and the conceptual understanding of black hole interiors.
  • Some participants propose that the rod will break due to the extreme acceleration required to maintain its position above the event horizon, rather than tidal forces.
  • Others argue that the proper acceleration needed to hold a rod stationary near the event horizon approaches infinity as it gets closer, suggesting that no material can withstand such conditions.
  • A later reply questions the relationship between tidal forces and proper acceleration, suggesting that the term "tidal force" may be misleading in this context.
  • Participants discuss the impossibility of free-fall orbits close to the event horizon, with some clarifying that powered orbits require more thrust than static hovering.
  • One participant raises the idea that a human could fall into a supermassive black hole without being torn apart, prompting further exploration of the differences between small and supermassive black holes.
  • There is a discussion about the nature of events inside a black hole and their relationship to an external observer's world, with some suggesting that the interior is part of one's causal future but never the past.
Participants express differing views on the effects of tidal forces versus acceleration on the rod, and there is no consensus on the implications of falling into a black hole or the nature of orbits near it. The discussion remains unresolved regarding the precise definitions and behaviors involved.
Limitations include the dependence on the definitions of terms like "tidal force" and "world," as well as the unresolved complexities of the physics involved near a black hole's event horizon.
black hole 123
if there's a really good rocket hovering just above a super massive black hole with very low tidal force, and it dips a rod just inside the event horizon, will the rod break? it seems a certainly but the tidal forces are very weak.
is it like dipping ur feet into piranha infested water? so when you lift the rod back up you see everything below the horizon gone missing?
black hole 123 said:
will the rod break?
Yes. The acceleration needed to stop something falling into the hole approaches infinity as it approaches the horizon, so the rod must break.
Rather like the letters y and o, yes. In practice a lot of stuff above the horizon will be gone as well because all materials have a finite tensile strength. But everything that crosses the horizon will necessarily not return. That's what crossing the event horizon means - it's not coming back.
  • Haha
What breaks the rod is not tidal forces. It's the acceleration of the rocket. The rocket is pulling at the rod very, very hard, and as the rod is lowered it gets more and more difficult for the points in the rod to keep up with the rocket. At some point, because the internal forces in the rod that are transmitting the pull of the rocket have a finite speed of propagation, the rod will break because the lower part of it simply can't keep up with the pull any more.
is it like dipping ur feet into piranha infested water? so when u lift the rod back up u see everything below the horizon gone missing?
The proper acceleration required for a point on the rigid rod to "hold station" in the limit of a very large black hole with "low tidal forces" will approach ##c^2 / d##, where c is the speed of light, and d is the distance from the event horizon as measured by static observers.
To put some figures on this, one meter from the event horizon, the acceleration will be ##\approx 9\,10^{16}## m/s^2, or ##\approx 9 \, 10^{15}## , i.e. 9,000,000,000,000,000 Earth gravities.
So as the distance d (as measured by static observers) approaches zero, the proper acceleration to hold station increases without bound. This means that no rocket at the bottom of the rod can accelerate hard enough to keep it from falling into the event horizon, and it also means that any rod that dangles down from the top of the rocket, no matter how strong, will break.
Trying to orbit the black hole won't work either, by the way - it makes things worse.
It may seem self contradictory to say that the tidal force is "small", if the proper acceleration is 9,000,000,000,000,000 gravities at 1 meter away from the horizon, but only 4,500,000,000,000,000 gravities 2 meters away from the horizon.
It's not really contradictory, though one could argue that the use of the term "tidal force" is a bit unfortunate. If we take the expression for proper acceleration, ##c^2 d^{-1}##, and differentiate it, we get ##-c^2 d^{-2}##
One might think that the tidal force "should be" the rate of change of proper acceleration with respect to distance away from the horizon, but this turns out not to be the case.
I will also point out that if we drop a spring through the event horizon of a black hole, in the specified limiting case of a very large black hole, the spring will not stretch. So there is something to the idea that the "tidal force" is zero in the case under consideration.
It's difficult to be more precise than this without going above the B level.
If by "orbit" you mean "free-fall orbit", that's not even possible that close to the hole's horizon.
Free fall orbits are not possible inside the photon sphere at 1.5x the Schwarzschild radius, as you say. Powered circular orbits which involving thrusting away from the black hole with rockets, are possible [add: inside the photon sphere], but such orbits demand more outward thrust than it takes to hover in place statically.
pervect said:
Powered circular orbits , which involving thrusting away from the black hole with rockets, are possible, but such orbits demand more outward thrust than it takes to hover in place statically.
Yes, agreed.
thanks for the answer. i forgot its the pull of rocket not tidal force. pervect is that for a small black hole? a human can fall into a supermassive black hole and not be torn, and (most) humans are over 1 meter in length.
also about the inside of the black hole, can it be thought of as simply outside an external observer's world? because it doesn't make sense to ask "whats happening inside the black hole in our galaxy core right now at 6 pm".
Without a precise definition of "world" in this context, it's hard to say. You can always choose to enter a black hole, for example - so is it really a separate world?
The interior (or part of the interior, anyway) of a black hole is in your causal future - you can affect events there at least in principle. It is never in your causal past unless you fall in - you can never be affected by events inside the hole. That's probably the strongest statement you can make.
An object in free-fall experiences no proper acceleration. What @pervect was talking about was objects experiencing extreme proper acceleration to “hover” just above the event horizon of any black hole. As he said, proper acceleration increases without bound for objects hovering closer and closer to the EH.
  • · Replies 51 ·
  • · Replies 62 ·
9K
  • · Replies 46 ·
9K
  • · Replies 73 ·
  • · Replies 43 ·
  • · Replies 20 ·
  • · Replies 57 ·
  • · Replies 29 ·
  • · Replies 67 ·
