Can a volume of gas exert pressure on itself ?
  • Context: Undergrad
  • Thread starter Thread starter nishantve1
    Gas Pressure Volume
The discussion revolves around the concept of whether a volume of gas can exert pressure on itself, particularly in the context of a rotating cylinder filled with gas. Participants explore the relationship between pressure, centrifugal forces, and the behavior of gas in a non-inertial reference frame.
  • One participant questions the source of the inward force on a differential mass of gas in a rotating cylinder, suggesting that the gas might exert force on itself.
  • Another participant draws a parallel to atmospheric pressure, arguing that the pressure gradient in the atmosphere is in equilibrium with gravitational forces, similar to the centrifugal forces in the rotating gas setup.
  • A participant discusses the centripetal versus centrifugal force debate, suggesting that the gas's rotation causes a change in velocity direction, resulting in an inward acceleration that prevents the gas from moving tangentially.
  • One participant derives a differential equation relating pressure variation with respect to position in the cylinder, showing how pressure changes due to the rotational motion and expressing it in terms of the ideal gas law.
  • A final participant expresses satisfaction with the discussion, indicating they have resolved their confusion regarding the topic.
Participants express differing views on the nature of forces acting on the gas, particularly regarding the existence and interpretation of centrifugal force. The discussion includes both supportive and challenging perspectives, indicating that multiple competing views remain.
The discussion includes assumptions about the behavior of gases in rotating systems and relies on the ideal gas law, which may not account for all conditions present in the scenario. The derivation of pressure as a function of position assumes a specific model of gas behavior that may not be universally applicable.
nishantve1
So, I was going through the solved problem sets and encountered this question which is to find the relation between two ends of a cylinder filled with gas rotating about a vertical axis fixed at one end (the red axis) .
I understood the solution but there is one thing still confusing me, the solution said that the force on the dx part would be one due to its rotation (let's say there's dm mass of gas there)
[itex]m\omega^{2}x[/itex] that's alright but the solution also said that there'll be a force towards the inside which will be( A is the area of cross section of cylinder) [itex]Adp[/itex] . Where does this come from ? Does the gas exerts force on itself ?
This is not a homework question .
It does - just look at our atmosphere, where pressure is decreasing with increasing height. It is the same concept. The decreasing pressure is in equilibrium with the gravitational force on the gas - which gets replaced by centrifugal forces in your setup.
That sounds like the centripetal vs centrifugal argument eg The one that says centrifugal force doesn't exist and that there is only centripetal force and that acts inwards.
The gas is rotating around the red axis so the direction component of it's velocity is changing. That implies an acceleration towards the centre. Essentially the base of the tube is pushing the gas sideways forcing it to move in a circle and preventing it flying off at a tangent.
In this system, the pressure varies with x: P = P(x)
Take as a free body the mass between cross sections x and x + dx:
dm = ρAdx
The force exerted by the gas located beyond (x + dx) on the mass dm is -P(x+dx)A. The force exerted by the gas located closer toward the axis on the mass dm = P(x)A. The net force on the mass dm must be: A (P(x) - P(x + dx)). This must be equal to the mass dm times the acceleration:
-(ρAdx)ω2x = A (P(x) - P(x + dx))
Expressing this as a differential equation, it becomes:
ρω2x = dP/dx
If we express the density using the ideal gas law, we get:
PMω2x /(RT) = dP/dx
or
dlnP/dx2 = 2Mω2/(RT)
where M is the molecular weight of the gas.
so P(x) = P(0) exp (2Mω2x2/(RT) )
Thanks everyone I got it finally !
  • · Replies 69 ·
  • · Replies 35 ·
  • · Replies 45 ·
