Can an imminent laser strike ever be observable?
The discussion centers on whether a laser strike can be observed before it impacts a target, particularly in the context of relativity. It is established that light travels at a constant speed, meaning that any light emitted from a laser cannot be seen before the laser itself reaches the observer unless there is a shorter path for the light to travel. The idea of "leading the target" is explored, but ultimately, it is concluded that without an indirect path or some form of intervention, the observer cannot see the laser before being hit. Additionally, the complexities of light behavior in space, such as scattering and the need for a medium to visualize the beam, are highlighted. Overall, the consensus is that observing the laser before impact is not feasible under the laws of physics as we understand them.
  • #51
Janus said:
No, everything doesn't change. Everything, regardless of how fast it moves are subject to Relativity. For example, in Newtonian Physics, you add velocities by V1+V2= VT, but in Relativity, it is (V1+V2)/(1+V1(V2)/c^2)
If V1 is 0.001c and V2is 0.001c, then Newton says they add to 0.002 c, but Relativity says they add to 0.001999998... c. The effects are still there. they just become less noticeable at speeds significantly less than c.
That’s new and different, then, from the thinking here, - that if I’m going C minus “1 iota”, a laser streams past me, at difference between no velocity, and C.
  • #52
davidjoe said:
That light does not go faster when emitted from a moving platform is not troublesome to me. Sound waves also do not exceed the speed of sound, when propagating from a moving car.
What strains my brain, is that light passing me from an independent source, when we are traveling at the smallest difference in speed, will pass me at light speed, as if I’m not moving at all. This is especially troublesome, because if that special speed is reduced by the slightest amount, everything changes. Now it passes me according to classical physics motion analysis, meaning it barely passes me whatsoever.
This is simply not true.
No matter what speed you are doing* - be it 0 or .9999c or anything in between, light will propagate at c.
* note that "speed" is relative to some physical reference point - a planet, a star, a galaxy, whatever. And it's arbitrary which one you pick. You are always at rest in your own reference frame and it is the planets and stars that are moving. And in your own reference frame, light always moves at c.
  • #53
Well, I must have misunderstood. I thought it has been said I will observe light pass me at a difference of C, “because all frames observe the speed of light as the same”. I took this to mean that if I’m stationary, it passes at C. If I’m one iota slower than light, at the same spot when it passes, that’s a reference frame, and therefore I see it pass at C. Or I don’t see it, rather, but that’s what happens.
See post 37 and there about.
  • #54
Post 37 and circa…. I read those to say it passes me as if I’m not moving, as I see it from my frame.
It’s one, or the other. I think both possibilities have been elaborated upon as the result. Possibly a reply to the others besides mine, would be in order.
  • #55
Let’s try to clear this up. If I am going one iota under light speed, and a laser beam approaches me on a virtually parallel path that is a few feet to my right, does it, as I see it:
A) pass by me at the “difference” of the speed of light; or,
B) creep up to, beside, and go in front of me, spread out over many lifetimes, because there is almost no difference in our speeds?
This is the pressure point. Where classical and relative part ways: only the speed of light is deemed the same from all reference frames. So, one of these can’t be right, I believe. I don’t know myself, only curious.
  • #56
It will go past you at c but the frequency will be (red) shifted, possibly by so much that it will be beyond the visible red part of the spectrum. (Like the light that arrives from the most distant receding galaxies)
"creep up" is not the right way to say it because it is still at c, relative to yo.
  • #57
Light goes by everything, whether moving or not, at C. Light is always going C, right, so that is a given; it’s the difference in perceived speeds that is the question.
It’s a very granular, specific hypothetical sub question, not meant to put anybody on the spot. Do my senses, biological and/or mechanical contained in my near-C vessel, perceive it pass by me in fractions of microseconds, or thousands of years, given that my speed is virtually the same but infinitesimally less than C?
It’s really got to be an A or B, or neither type answer, right? If light is gaining on me from a lead of a second, at an inch a day’s difference in speed, creeping up is a good word choice.
  • #58
No it's not. The perceived speed to the fast moving observer is c - always. As I mentioned, for consistency, the perceived wavelength is shifted.
Only in your world. You need to adjust your model if you want to understand this; you can't force reality to fit your ideas, I'm afraid.
Likes Vanadium 50
  • #59
So, A, the laser is perceived to pass the ship at light speed, and the ship’s speed marginally under C, does not matter. The ship being passed by the laser, observing it and only it, could not discern any difference between standing still or almost traveling at C.
If the laser was any object infinitesimally slower than C, the hard and fast observation of it traveling at C does not apply, and I believe I would observe it for a great length of time, or B, because our speeds are nearly identical.
Am I wrong about ONLY light speed being observed as a constant from all reference frames? This does not apply to any lesser speeds, right, it’s a bright line distinction?
How can the options of “A or B or neither” be objectionable? How can “neither” be left out of the quote box? It’s like ending the quote as “It’s got to be A”.
  • #60
Light does not allowed to reduce its speed by the smallest amount.....nor can you actually reach the speed c. The physics falls apart. So not a problem: it doesn't happen
davidjoe said:
As to traveling alongside light, he did analyze that. But as I understand our view of relativity, no, there is no such thing
He pointed out the problem.
davidjoe said:
if light is not subject to platforms or frames varying its perceived speed, then they are incapable of affecting its constancy, which they do, evidently as light propagating from a locomotive or a pedestrian both reach an equidistant point at the same time.
Why would light care what a locomotive or pedestrian are doing? It is just being light.
No. Your perception of how velocities in moving frames of reference actually add is incorrect. (V1+V2)/(1+V1(V2)/c^2)
davidjoe said:
How can the options of A or B or neither, be objectionable? How can “neither” be left out of the quote box? It’s like ending the quote as “It’s got to be A”.
I think this is not logical, although I am unsure the question you are asking.
  • #61
I’m playing by the rules, Hutch. I’m not suggesting an object reach or exceed light speed.
I’m simply examining the constituent components of relativity.
Relativity does not require suspension of any logical precepts, to my knowledge.
Without reaching the speed of light, by only the slimmest of margins, your speed of C minus one iota, is NOT a constant in all reference frames, and has more in common with .00011 mm per year, than it does with C, right, with respect to how your speed is perceived by others.
This shouldn’t be an avoided question to my thinking, right, relativity is a theory, not a person being examined on a table.
  • #62
Correct.
Correct.
Correct.
But then you said this:
Which is incorrect.
Likes sophiecentaur and davidjoe
  • #63
davidjoe said:
... relativity is a theory, not a person being examined on a table.
The theory part is Einstein's curved space-time - a model of how light behaves the way we see it behave. But the observations are incontrovertible.
No matter what your frame of reference - whether you are moving or stationary, relative to some planet or star or galaxy, you will always observe the speed of light (in a vacuum) to be c.
Any theory that wishes to explain light must address that fact.
There are reasons for why it may not make sense at first, but it requires going down the rabbit hole of relativity. I'm not sure you are ready to make that journey yet. It requires throwing away your classical preconceptions and not drawing hasty conclusions from what you have learned about the classical world - which is kind of what you are doing now.
It's sort of beyond a single forum thread. The best way would be to pick up a basic primer book on relativity.
Likes PhDeezNutz and davidjoe
  • #64
With respect. I have no desire to examine theory of relativity: I have made my peace with the intuitively difficult parts long ago, and recapitulating the tenets will likely not be useful to you. In fact what is subject to examination is your inability to understand the theory because of prejudices you do not seem to realize that you have. These are what is on the table. It requires you to ask specific guestions about the theory; not complain about our answers. Hopefully something will click and illumination will result. Or perhaps not. Your questions are not trivial or foolish but you need to be open to the very good answers being supplied to you. And please make your questions about theory and not epistomology
Likes PhDeezNutz, russ_watters, Vanadium 50 and 1 other person
  • #65
You are moving at say 0.9999c relative to laser emitter. To find the speed the light moves relative to you, As measured by you, Newtonian physics says you use 1c-0.9999c = 0.0001c.
With Relativity, you use (1c-0.9999c)/(1- 1c(0.9999c)/c^2. A bit of simplifying yields (1c-0.9999c)/(1-0.9999c^2/c^2) = (1c-0.9999c)/(1-0.9999) = c(1-0.9999)/(1-0.9999) = c. as long as the magnitude of one of the velocities you are working with is c, you get an answer of c.
  • #66
That introduces GR. It is not part of the OP's question, which is just about Special Relativity. I think that one step at a time is appropriate here.
The OP's problem seems to be that he wants to introduce some particular speed which is a barrier between one set of observations and another. The fact is that Special Relativity operates, whatever speed you are going at; it's just that the effects are very small at speeds which are achievable by an observer.
I have made the point twice (and he doesn't seem to have picked up on it) that is there are other effects / consequences of the invariable speed of light. Apparent distances, apparent times and apparent frequencies change at (mostly) high relative speeds so the OP's problem of light suddenly behaving differently is irrelevant; Nothing is fixed apart from the speed of light; the rest of Physics fits itself around that. AND our personal views or mental models have to fit in with it too. There's no way out of that.
It certainly required suspension of the views of many very clever people in the early twentieth century. You, also, may need to re-examine what you mean by your 'logical precepts'. They are preconceptions and not necessarily logical; they do not fit with measurements, for a start.
  • #67
New address for the thread SR. I still pose this sub question:
“If the speed of light is reduced by the slightest amount, (in the form of a fast object), is it observed to be constant, from all reference frames?”
My understanding is that this distinction applies to only light speed. It IS is a bright line difference.
  • Skeptical
Likes Motore
  • #68
“If the speed of light is reduced by the slightest amount, (in the form of a fast object), is it observed to be Constant, from all reference frames?”
The speed of light IS the speed of light. You cannot change it. c is universal. Your post is meaningless.
A "fast object" cannot travel at c. I assume that you have gone to the trouble of finding out the formulae.
A "bright line" doesn't apply here - any more than a temperature of Zero K. You can get as close as you like - depending on how much money and energy you are prepared to expend but you are still a massive object and you will follow the SR formulae,
  • #69
I’m not suggesting that light be slowed. And I think that is clear in the posts. Light travels at C. But objects can be accelerated to just an iota under C.
If it is inconvenient that a striking difference exists in how two speeds are observed in all reference frames, when the difference between them could be the smallest possible, that doesn’t make the question or the post meaningless, does it?
  • #70
Maybe take a step back, choose a simpler scenario, clearly define everything: which reference frame measures which thing, which objects have which speed RELATIVE to each other, ...
Do not forget, that each object can regard itself at rest and each object sees the light going at c.
For example you have the earth and you have a laser that has 0.999c velocity relative to the earth. You are standing on the earth and you "see" (not literally) that the light emitted from the laser is going at velocity c and the laser is slowly lagging just behind that light. Now you go sit a on the laser and you are at rest, stationary and you "see" that the earth is going by with 0.999c velocity, but the light from the laser is still going away from you at c and you (the laser) are not lagging slowly just behind the emitted light.
Likes davidjoe and DaveC426913
  • #71
Objects can be accelerated to just under c, yes. And if you are on that object, and you measure a beam of light - any beam of light, in your object or outside it - you will measure it to be travelling at c.
What you are not factoring in is time dilation.
There is a simple scenario that involves a spaceship and a flashlight (or headlights) that shows what happens when two observers see different things, depending on where they are - I'm just not sure you're ready for it.
Likes davidjoe
  • #72
Yes, Special Relativity is mathematically less convenient than Galilean Relativity, but it fits observation better. Convenience is also the reason why Galilean Relativity is still being widely used, where its errors are negligible.
Likes russ_watters and davidjoe
  • #73
You can see why we are puzzled.
  • #74
Dave, I will definitely delve deeper. I have done a surface level look to see what NASA’s position is on this, just out of curiosity. Just begun so nothing to say about that.
I’m not for or against AE. I believe that is is possible to understand, be accepting of and critical of, a theory, all at the same time.
Fuller context than the quote box clears that up.
  • #75
It is meaningless to me. If you actually specify the precise situation and what exactly it is that the various observers are measuring then is all follows perfectly - as long as you realise that they will all see the same beam of light going past them at c. But its 'colour' may be different.
  • #76
If it’s not striking, then it’s possible that the point blended with everything else.
Envision, we’ve left port with sister cruise line ships that are so close to our speed we never lose sight of them, right?
If I’m being overtaken in the lead at such a slow rate from the Yucatán, that only by Galveston does the sister ship pass me, … BUT should that sister ship in the rear add .0000001 MPH to it speed, I will see it go by me at light speed, well, that is striking, no?
In my hypothetical, as this turned about halfway down, everything illustrated and discussed was either my ship 2 iotas under C, a missile pursuing it 1 iota under C, or light at C, both starting a second behind me. I look at the missile for what, 100 lifetimes, but add to the missile’s speed the slightest imaginable increase in speed, which is a laser’s speed, and I would see it pass me at light speed as it if I’m completely still.
  • #77
Rive said:
Nope. Light is going the fastest (straightest) between two points: anything sideways will be just slower.
In a flat space time, this is correct. In a curved space time, things are not quite so simple. There can be multiple trajectories between two events. Not all such trajectories need have equal transit times.
Consider, for instance, a laser beam that fires a few tens of meters away from your face on a starry night. It is aimed skyward at a black hole some hundreds of light years away, on a trajectory that nearly grazes the photon sphere so that the beam will loop around and come back to strike you some hundreds of years later.
In the mean time, light from dust that the beam has illuminated on its outward path might theoretically be seen hundreds of years before the final strike.
  • #78
A ship cannot go at light speed. And what Lorentz Transformations give you is not what you actually see visually, but what is reconstructed to happen in a certain frame, after accounting for signal delay due to finite lightspeed.
  • #79
I don't think it does.
Further, we are almost 80 messages in, and we are still reading confusing and impossible things from you - despite having been shown where these are wrong. For example, "I will see it go by me at light speed" is something that material objects do not do.
Likes hutchphd
  • #80
The “it” going by me was light. And probably 4 people said that, before me. So…
If you’re referring to the cruise ships, man, is that not obviously an analogy?
  • #81
Apart from the illustrations, - and perhaps this is too sensitive to the core of SR to even acknowledge - but only C (a very specific speed) is claimed to be observed as constant in all reference frames.
Take away one iota from light speed, the smallest conceivable change, and now that new speed, which objects can go, is NOT observed as a constant in ALL reference frames. That new speed is frame dependent. If you are matching it, beside it, looking at it, no relative motion is perceived.
Add the small delta increase to it, which only light can go, and now you see a beam of light pass you at light speed as if you are not moving at all.
  • #82
Right, a ship cannot. The three objects in question were my ship, a missile and the laser. Laser = C; missile = just under C; ship = just under laser.
  • #83
You can only draw valid analogies when you understand your subject. You cleasrly do not so your anaolgy means nothing.
Have you actually read around this topic or is your only inout from your questions and PF's answers? Q and A is a hopeless way of learning on-line. It actually only works well for very receptive bright minds who are 'almost there'. Your random responses have ben taking you further and further from reality because you seem not to want to be wrong.
  • #84
No, you were talking about a "sister ship" that you "will see go by me at light speed"
As already said, a ship cannot go at light speed.
  • #85
Somehow the original, ship, missile, laser hypothetical image blended.
The ships were recasting the same scenario in different terms. Some of my references to the “speed of light” or maybe light speed are not to light, but to that specific speed.
I agree, completely that the final step up in speed, is made by light. But the final step up need not be a big one. That is my point.
The final step up could be an inch a year, or infinitely smaller than that. But the final step up has enormous consequences to whether all reference frames are required to see light (the speed of light in a vacuum) as a constant, or not.
That smallest change in velocity is the difference between conceivably looking at a trailing missile for millennia, (if you and it are only slightly sub C) or seeing a laser pass by you, as if you are not moving at all.
  • #86
If there are only three things in the universe, your ship, the missile and the laser, from slowest to fastest, whether you are going 1 mph and the missile 2 and the laser C, or you are two iotas under C, the missile is one, and the laser passes both at C, looking at the laser, you are going to see it pass you at the difference of C.
  • #87
Increasingly complicated hypotheticals will not help.
  1. There is no absolute speed. "One iota less than c" is observer dependent.
  2. Massless objects (like light) always travel at c. All observers agree on this.
  3. Massive objects always travel slower than c. Observers can disagree about their speed and even their direction.
Likes hutchphd, Motore and ersmith
  • #88
davidjoe said:
If there are only three things in the universe, your ship, the missile and the laser, from slowest to fastest....
Some of your difficulty with relativity may come from not fully appreciating how this description is incorrect (or more precisely, includes a hidden assumption that is incorrect). It makes no sense to talk about the speed of the ship being more or less than the speed of the missile - all we can talk about is the speed of the ship relative to the missile when we consider the missile to be at rest and its negative, which will be the speed of the missile relative to the ship when we consider the ship to be at rest.
Likes ersmith
  • #89
This is not true. The enormous consequences you speak of are due to your misunderstanding of the scenario.
It looks like you are pretending that you could get your spaceship to a tiny bit below the speed of light and everything is classical, but if you could boost it juuuuuust that little bit extra, everything would change.
No.
All things with mass, such as spaceships and atoms, move at slower than c. Always.
All massless things, such as light, move at c. Always.
You cannot swap them back and forth. You cannot jump from your spaceship onto a beam of light - even hypothetically - and ask what you would see. It is non-sensical.
You in your spaceship, have a frame of reference in which you are stationary (that's the definition of a FoR). No matter how fast you are moving with respect to any other object in space, you are stationary in your own reference frame, and measure everything around you in that frame.
Light has no reference frame. It can't, because that would entail a reference frame in which it is stationary - which directly contradicts the axiom that light moves at c in all reference frames. It can't be stationbary and moving at c simultaneously.
So there is no "final step". There is massive object and massless objects, and ne'er the twain shall meet.
Likes hutchphd
  • #90
Well yes, that is a claim, but so is the claim that there is only one natural number ##N## such that ##2+2=N##. That claim is backed up by a mathematical proof starting from the axioms of number theory, but of course you don't need a lot of advanced mathematics to satisfy yourself that ##2+2=4## and never anything else.
Likewise it has been mathematically proven that either there is no invariant speed, or if there is, then there is exactly one. And likewise, you don't need the math to satisfy yourself of this - just assume that there are two, play around with various objects moving at various speeds relative to one another and greater or less than one or both of your hypothetical invariant speeds, and you will quickly arrive at a contradiction.
So the question has always been whether there is no invariant speed, in which case we have Galilean relativity and velocities add as ##w=u+v##; or there is one invariant speed, in which case we have Einstein's relativity and velocities add according to ##w=(u+v)/(1+uv)##. (And note that the "very specific speed" doesn't show up in this formula at all because I've sensibly chosen units in which the invariant speed is unity).
It's actually something of an accident of history that we call the invariant speed "the speed of light" and represent it with the same symbol ##c## that we used for the measured speed of light. A more modern view would be that there is an invariant speed and the interesting question about light speed is whether light moves at that speed, or at some speed so close to it that our most sensitive measurements have been unable to find any difference.
Likes hutchphd, Motore and davidjoe
  • #91
Nugatory said:
Some of your difficulty with relativity may come from not fully appreciating how this description is incorrect (or more precisely, includes a hidden assumption that is incorrect). It makes no sense to talk about the speed of the ship being more or less than the speed of the missile - all we can talk about is the speed of the ship relative to the missile and its negative, which will be the speed of the missile relative to the ship.
The missile is introduced only to illustrate a certain contrast.
Neither your ship nor the missile can attain light speed but are not prevented from traveling just under it.
The purpose of the missile is simply to relate that an object ever-so-close to the speed C, can be in your view eternally, basically.
However, add that tiniest additional speed, the delta between the missile and light, which brings to bear the laser, and now that thinnest of differences in velocity results in seeing a velocity difference of, the speed of light.
In the first thread I posted, if I remember correctly, many pages over many days, it was stated by a member that we no longer use infinite mass in relativity to represent what happens to matter at light speed. But I believe in AE’s time, infinite quantity may have been a nonnegotiable.
To my mind’s thinking, if infinite mass is problem, and I for one think so, (and have since school) such a distinct line between two particular speeds that are virtually identical, may also be.
  • #92
To your last paragraph, the only logical answer is that the particular “speed” is what is invariant, not what speed light goes, in my opinion. Particularly, again my opinion, it’s that speed which represents 100% of that which is attainable, and it happens to be that electromagnetic radiation fills that position, alone.
  • #93
@davidjoe in 91 posts you have not shown a single line of math. Without math you are just waving your hands, and nobody else can have any precise understanding of what you are talking about. Physics is not done in vague ordinary language. It's done in math.
Here's what the math you need to do should include: pick an inertial frame (the easiest would be the one in which the laser's target is at rest, but if you prefer to use one in which the target is moving at 0.99999c, be my guest, the laws of physics are invariant); write down the equation of the worldline of the laser pulse and the equation of the worldline of the target; find where they intersect; and then search for any path from anywhere on the laser pulse worldline that (a) is not spacelike, and (b) intersects the target worldline before the laser pulse worldline does. After you have failed at enough attempts to find such a path, perhaps you will see why it is impossible. But you will not see it by continuing to concoct more and more complicated assemblages of vague ordinary language.
  • #94
This is quite correct--and entirely irrelevant to the question you are struggling with in this thread.
Likes hutchphd and russ_watters
  • #95
Are you confusing the closing speed between two things with the velocities of the two things?
I consider myself to be at rest. A ship passes me moving at speed .99999c.
That ship emits a flash of light in the direction of its travel. I will measure (the question of how I perform these measurements is irrelevant here, but also not trivial) that the flash of light is moving at speed c relative to me. I will measure that the flash of light is gaining on the ship at speed .00001c, calculated by subtracting the forward speed of the ship from the forward speed of the light.
The ship also launches a missile in the direction of travel. Say that this missile moves at speed .5c (relative to its launcher, of course). I will measure its speed to be .9999967c. So how fast is the light gaining on the missile? It's .0000033c, the forward speed of the light minus the forwards speed of the missile. How fast is the missile gaining on the ship? It's the forward speed of the missile minus the forward speed of the ship.
So we aren't treating the speed of light differently here - it adds and subtracts just like the subluminal speeds of the ship and the missile. Relativistic corrections only come in when we add speeds measured in different frame (here the .5c of the missile using a frame in which the ship is at rest and the .99999c speed of the ship using a frame in which I am rest); then we must use the relativistic velocity addition formula which also does not treat the speed of a flash of light differently than the speed of anything else.
  • #96
I’ll come back. Client stuff.
  • #97
You really are desperate not to be wrong. But you are. No amount of analogies and arm waving will make Einstein's Special Relativity fit your daft idea. Learn some maths and then read Einstein's own Book on Special Relativity. It is not hard to follow what he says (if you are not convinced he's wrong.
  • #98
If by "that speed" you mean the invariant velocity, then yes, of course, everyone has understood that for many decades.
It's a distinction without a difference though, if light also moves at that invariant speed and there are many good reasons to think that it does.
One hand-waving but fairly convincing argument is that we can calculate the speed of light directly from the laws of electricity and magnetism; these laws are the same in all frames so yield the same speed in all frames. So we expect that the speed of light will be invariant, and we've established by other means that there can be only one invariant speed, so we conclude that either something is wrong with our understanding of E&M or the speed of light and the invariant speed are necessarily the same.
Note 1: The invariant velocity shows up in contexts other than electromagnetic waves. Gravitational waves propagate at that speed, and it is a key element of relativistic quantum field theories, even though these have nothing that we would recognize as a "speed".
Note 2: Were it to turn out that light does not move at the invariant velocity, the metrologists would have to look long and hard at the definition of the meter. We wouldn't have taken this chance if there was any realistic possibility of this happening.
Likes PeterDonis
  • #99
We will be talking.
Likes DaveC426913
  • #100
@davidjoe, you should also try a more modern textbook. This is an “as well as” not an “instead of” recommendation (although if you’re only going to do one, it should be the modern one), and Taylor and Wheeler’s “Spacetime Physics” which is available free from https://www.eftaylor.com/spacetimephysics/ is my first choice.
Einstein developed special relativity 120 years ago starting with the perspective of a turn-of-the-last-century physicist, as opposed to that of a motivated 21st century student. Since then generations of physicists have built on that work, corrected some wrong turns, and starting with Hermann Minkowski enormously strengthened and simplified the presentation of the underlying principles.
Likes davidjoe
