Can any one me identify this object?
  • Thread starter Thread starter wild69er
The object found is believed to be made of marble, with semi-polished surfaces and tapered threads, measuring 3.75 inches in length and weighing 12 ounces. It may be a Victorian period cistern pull or the working end of a pestle, though it lacks the expected wear for a pestle. The discussion emphasizes the importance of searching the surrounding area for additional pieces to better understand the object's context. Suggestions include using a metal detector to locate any associated fittings or components. The mystery surrounding the object invites further exploration and investigation.
wild69er
I dug up this object with a rototiller on a friend of mines lot that he has owned for 40 years. I believe this is made of marble. It is semi polished. The inside threads are tapered. I have given the dimensions below. Please help.
LENGTH 3.75"
TAPERED WIDTH 2.25" to 1.50"
THREADED HOLE WIDTH .75"
HOLE DEPTH 1.75"
WEIGHT 12oz.
It could be a Victorian period cistern pull .
A brass fitting goes in the hole and this is connected via chain to the cistern lever .
Most commonly made of china , ivory or wood .
A slightly more posh one
Likes CWatters
It could also be the working end of a pestle .
http://ab.wsimgs.com/wsimgs/ab/images/dp/wcm/201614/0096/porcelain-mortar-pestle-c.jpg
Likes Buckleymanor
Of the two the pestle is the one.I had one like it.
The cistern pull has a hole all the way through it to secure the chain.
The pestle is smooth so it can grind.
It could be the marble handle of almost anything from an earlier time. Obviously the wooden part has rotted away. I would be looking for other pieces to see if you can't cobble some parts together and then get a better idea of what the greater object is. If you find something else don't forget to mark its location and its distance from the original object. Then you'll get a better idea of the size of the larger object that this marble handle is a part of.
And, yes, it does resemble a cistern pull. I actually looked at some online and they are usually connected to a metal fitting which is connected to a chain. I'd be sweeping the area in your garden with a metal detector. That is if you're still interested. Sometimes it's fun to do these little personal 'anthropology' projects.
It does not have the end wear expected on a pestle.
The thread does not look like a wood thread. Most brass tube is threaded with 26 tpi. What is the pitch of the thread ?
If marble, the hole would be drilled and tapped, then a bolt in a lathe would hold the article while the profile was cut and polished.
And even if it was wood, there should probably still be a brass or copper fitting. That's why he should go back in with a metal detector. Any mystery is a good mystery.
