Can anyone check my working on the tension upcoming test question
The discussion revolves around checking calculations related to tension and forces in a physics problem involving a pulley system. The initial calculations for tension (T) and horizontal force (RX) appear correct, but there are noted errors in the vertical force (FY) calculations, particularly regarding signage and the vertical component of tension. Participants suggest re-evaluating the forces in the y-direction and correcting the approach to simplify the problem. There is also a debate about the necessity of calculating the pulley resultant force, with some arguing it complicates the solution unnecessarily. Overall, the focus is on ensuring accurate calculations and simplifying the problem-solving process.
cracktheegg
[URL=http://s1345.photobucket.com/user/Duk_Bato/media/Untitled_zps84f60bfd.png.html][PLAIN]http://i1345.photobucket.com/albums/p679/Duk_Bato/Untitled_zps84f60bfd.png[/URL][/PLAIN]
ƩMA = Ʃ r x F
1.6 * T+ 0.8 * sin 40 *T = 1.2 * 250
T (1.6 + 0.8 * sin 40 ) = 300
T = 300 / ( 1.6 + 0.8 * sin 40 )
T = 141.9 N
RX= 108.701
FY=141.9+141.9+250=533.8
RF= Root(533.8^2 + 108.701^2) = 544.76N
hi cracktheegg! :smile:
your T looks ok
is your Rx positive or negative?
check the signs in your Ry :wink:
ƩMA = Ʃ r x F
T = 141.9 N
RX= 108.701
Looks good to here, call it Ax
You have some errors here. You are looking for Ay by summing forces in the y direction = 0. You have signage errors and you forgot to calculate the vertical component of one of your tension forces. Assume Ay acts up, and try summing forces in the y direction = 0 again.
Make correction above and this will make the magnitude of the reaction force at A, correct.
I find the pulley Resultant force= 257.21
0=141.9cos40 - Rdy (up)
0=-141.9sin40 - 141.9 +Rdx (right)
root(Rdy^2+rdx^2)= 257.21N
tan^-1(Rdy/rdx) =65
-250+257.21sin65+Ray=0
Ray=16(up)
RX= 108.701
Rf= root(108.701^2+16^2)= correct?
i think you have your Rdx and Rdy the wrong way round (though that won't affect your final result)
but i don't understand why you're doing it this way …
the question doesn't ask for the pulley resultant, and finding it takes much longer and gives more opportunity for making mistakes :redface:
why didn't you simply do Ry for the beam?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
