Can anyone solve this riddle using programming softwares?
  • Thread starter Thread starter Basimalasi
    Programming Riddle
The discussion centers around a riddle involving connecting three black boxes to three red boxes without any lines intersecting. Participants agree that the problem is unsolvable in two dimensions, referencing similar puzzles like the Water, Gas, and Electricity problem. The consensus is that without using three dimensions or a non-Euclidean surface, such as a torus, there is no solution. One contributor expresses frustration over the need for an algorithm to explore all possible connections, while others suggest that since a solution does not exist, there is no point in using software to search for one. A C code snippet is provided to illustrate the conclusion that no solutions are possible.
Basimalasi
Hello computer science people,
riddle me this... you have three black boxes and three red boxes. You want to connect each black box with the three red boxes without making the lines interact with each other. can you do it ? or is it unsolvable ?
Like this :
Technology news on Phys.org
I've seen this many times in the past. To the best of my recollection, it is unsolvable (in two dimensions).
Is this possible ? there is no cut.
Like this?
skeptic2 said:
Like this?
I don't think this meets the requirements of a direct link between each red box with each black box, and vice versa. This might not have been stated in the OP but I believe that is what is implied.
Why would you want to use software to solve this puzzle?
Try designing a complex multi-layer printed circuit board without using a computer track routing algorithm. :smile:
skeptic2 said:
Like this?
nope
because i think its unsolvable
solving this riddle is like guessing a 6-charechters password..you have to have an algorithm that will test all the possible paths the 9 arrows are going to take from the black boxes to the red boxes without interacting
you can't make the lines go "through" the red boxes.
3 arrows from the first black box to all red boxes
3 arrows from the second black box to all red boxes
3 arrows from the third black box to all red boxes
without no interaction between the lines
Unless you use three dimensions - or the surface of a donut - it's easy to show that there is no solution.
Here is a link: http://mathforum.org/dr.math/faq/faq.3utilities.html
Since it's not possible, there is no point is having a computer search for one.
I know this stupid of me and a waste of your time guys but I can't be satisfied without an algorithm that would test all the possibilities
Code:
while there_exist_more_possibilities(); do test_next_possibility();
I don't have much time to waste, so I am not going much deeper. That's your algorithm, just fill in details.
I understand. You trust computers more than people.
Here's a more detailed algorithm. In fact, it's actual C code:
Code:
//  For an explanation of why this algorithm works, see:
//    http://mathforum.org/dr.math/faq/faq.3utilities.html
#include <stdio.h>
void main(void) {
printf(“Results from analysis of Red/Black box riddle: No solutions exist!\n");
Try it out and let me know if it finds anything.
Likes 1 person
