Can black body retain it`s absorbed heat energy?
A black body can retain absorbed heat energy, but this retention limits the ability to convert that energy into useful forms like electricity. The conversion process relies on a temperature difference; if the difference between the stored heat and the environment is minimal, energy extraction becomes inefficient. While black bodies are theoretical constructs, practical applications exist, such as using dark materials in solar furnaces to generate steam for power. The effectiveness of energy conversion is governed by thermodynamic principles, particularly the Carnot cycle. Therefore, while heat can be stored, its utility is contingent on the conditions under which it is extracted.
CHANDRABHAN
Can black body retain it`s absorbed heat energy? If yes, then why we can not convert this energy into a usefull form such as into electric energy as solar do?
Science news on Phys.org
Hi and welcome to PF.
If your black body retained its heat then, by definition of the word 'retained', the energy couldn't be retained.
On the other hand. a black body (say a dark painted brick) can be placed in a solar furnace (just to improve the process`) and the retained heat could be used to boil some water and work a steam engine / generator.
There's a sort of general principle that, to make anything 'happen', Energy has to be transformed from one form to another.
Yes. But the ability to extract energy depends on the temperature difference. See https://en.wikipedia.org/wiki/Carnot_cycle
So you can store any amount of energy, but if the temperature difference to the environment is too small, you can't extract it usefully.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
