Can boiling water inside steel cube make it explode?
9 replies · 2K views · last reply
evergrace
Hello
Lets say we have a steel cube, then fill it with water and close all the gaps very strong with welding. If we leave the cube on a stove for a lot of time, is the produced steam of the boiling water, enough to destroy and smash the steel cube?
What do you think and why?
Does the thickness of the walls of the cube matter?
Google for "boiler explosion".
Sure, if the sides of the cube are thin enough it won't be able to withstand the increase in pressure. Steam boilers used in old ships and locomotives could violently explode.
As an example:
Black-and-white photo of a steam locomotive wrecked on its side across the tracks, boiler and cab torn open, with bent rods and debris spread out.
Ok thanks, i have got my answer. So it is possible. I was just wondering, because the most common thing to hear is that the steam can kick out the lid of the boiler. I would not except, it would be able to destroy even the steel surfaces. I would like to try it one day, it will look very cool.
There are plenty of videos online if you want to see a steam explosion. Don't risk yourself or others doing something that you're not experienced with. Seriously, don't freaking do it. Even the explosions of a very small boiler can send shrapnel out that can injure eyes and cut arteries.
Ok thanks for the warning, but i want to try it. I will leave it boiling in a closed room and when i hear the BOOM i will go and check it out.
Do not do this. Deliberately creating an out of control explosion is dangerous and phenomenally stupid.
Chestermiller said:
Bad idea. Please don't do it.
Come on, what can go wrong? The steel cube will be small and i will be out of the room. I am not an expert but i don't think that it is so bad. Can the exploded steel cause serious damage even on the wall?
