Can Entangled Particles Enable Instantaneous Communication?
  • Context: High School
  • Thread starter Thread starter PeterPendragon
    Communication
The discussion centers around the concept of whether entangled particles can enable instantaneous communication. Participants explore the implications of entanglement in quantum mechanics, particularly in relation to the no communication theorem and the nature of measurement in quantum states.
  • Some participants propose that if entangled pairs could be used for instantaneous communication, one would still need to physically deliver half of each pair to the reception point.
  • Others argue that entangled pairs cannot be used for instantaneous communication due to the no communication theorem, which states that without outside information, one cannot determine if particles are entangled.
  • A classical analogy is presented to illustrate that while one can know the outcome of measurements on entangled particles, one cannot influence those outcomes to communicate information.
  • Some participants express a common misconception that altering the state of one particle in an entangled pair changes the state of the other, but others clarify that entangled particles do not have fixed states that can be controlled.
  • It is noted that once a measurement is made on one member of an entangled pair, the entanglement is broken, preventing further changes or communication.
  • Some interpretations of quantum mechanics suggest that while one particle's state may influence another, the randomness of the outcomes means that information cannot be transmitted.
  • Participants discuss the prevalence of misconceptions about faster-than-light communication in popular media, attributing it to oversimplifications and misinterpretations of scientific concepts.
Participants generally agree that entangled particles cannot be used for instantaneous communication, but multiple competing views exist regarding the implications of entanglement and measurement in quantum mechanics. The discussion remains unresolved on the nuances of these interpretations.
Limitations include the dependence on interpretations of quantum mechanics and the unresolved nature of how entanglement and measurement interact. The discussion reflects various levels of understanding and misconceptions about the nature of entanglement.
This discussion may be useful for individuals interested in quantum mechanics, particularly those exploring the implications of entanglement and communication theories within the field.
PeterPendragon
If entangled pairs can be used to communicate instantaneously, does that mean one of the paired particles has to be physically delivered to the reception point in order to establish communication?
If entangled pairs could be used to communicate instantaneously, you would still need to deliver half of each pair to the reception point.
However, entangled pairs cannot be used for instantaneous communication.
The reason is simple.
If you have a group of particles and no outside info...
(so you're trying to figure out what's going on based on what you yourself can measure)
...then there is no way of telling if these particles are halves of entangled pairs or not.
I believe it's called the no communication theorem, if you want to look it up.
Even if you would know that, you cannot use it for instantaneous communication. While a proper quantum mechanical description is a bit more complicated, here is a classical analogy that captures the relevant features: Write "yes" on one paper and "no" on another, put them in separate identical-looking envelopes and mix them, then give the envelopes to people far away. Before you open the envelopes you don't know which answer you will find. You know whenever someone opens the envelope and sees "yes" or "no", then the other envelope will have the opposite answer. But you cannot influence that answer, so you cannot use it for communication.
Thanks. I get that, but I thought if you altered the state of one pair (eg spin), you changed the other, hence communication?
You are not alone in this thought, but you are not correct. The problem in your intuition is that the entangled particles are not separately in fixed states that change. They are in a shared state and you cannot control which one ends up in which outcome. It is only guaranteed that they will be "opposite" states.
In some interpretations you change the other, but you still cannot predict in which way you change it - you change it randomly (simplified description). You can measure that afterwards, but then you cannot change it any more.
And just to add to DrewD and mfb's excellent replies: You cannot actually determine (or distinguish) whether A influences B (where measurement of A occurs before measurement of B) or the reverse (also where measurement of A occurs before measurement of B). That certainly takes the heart out of the argument that communication is occurring.
Okay, all this is great, I appreciate all the answers. Using mfb's paper analogy, it seems that since there are only two possibilities, of course when you open one, the other is the opposite. And, why can't you "change it anymore"? I thought the whole point was that if you changed the state of a member of an entangled pair, it's partner also changes. Could anyone recommend a good but relatively simple article or book I could read on this? Thanks.
Entanglement is broken once you measure the entangled property.
In some interpretations of quantum mechanics, not in all. That alone shows that you cannot transmit information.
That's not how it works. If you change the spin of either member, the entanglement is broken. All entanglement says is that if you measure one member of the pair, then you know what the value of the the corresponding measurement on the other will be, when and if such a measurement is made - for all you know, that other measurement has already been made. Furthermore, it only works for the first measurement on each member - after that the entanglement is broken.
"Sneaking a look at God's cards" by GianCarlo Girardi covers a lot more than just entanglement, but it's good and relatively simple.
Thanks all, especially mfb and Nugatory who really got me to understand. Okay, so maybe not for this forum, but why this, I think, common misconception about faster than light communication?
It makes great news headlines. Same with many other things - some oversimplified or misinterpreted statement produces more clicks than the truth. See also how often the Higgs boson is called "god particle" in the news. No scientists uses that name, that's a pop-science-only name.
Yeah, I used to work at NASA. You've seen the mermaid, human head, rat etc we've found on Mars!
  • · Replies 27 ·
